TI-Nspire Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
120
All Time:
18,388
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to install batteries into a TI-Nspire calculator to ensure that it will turn on.
Parts
    1. TI-Nspire Battery Replacement, Battery: step 1, image 1 of 1
      • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
      • Slide the front cover down to remove it.
      Ask FixBot
    2. TI-Nspire Battery Replacement: step 2, image 1 of 2 TI-Nspire Battery Replacement: step 2, image 2 of 2
      • The calculator should be facing front with the screen on the top and the keypad on the bottom.
      • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
      • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
      Ask FixBot
    3. TI-Nspire Battery Replacement: step 3, image 1 of 1
      • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
      • Slide the switch until it moves from the left side of the button area all the way to the right side.
      • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
      Ask FixBot
    4. TI-Nspire Battery Replacement: step 4, image 1 of 1
      • Turn the calculator back to the front as you would normally use it.
      Ask FixBot
    5. TI-Nspire Battery Replacement: step 5, image 1 of 2 TI-Nspire Battery Replacement: step 5, image 2 of 2
      • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
      Ask FixBot
    6. TI-Nspire Battery Replacement: step 6, image 1 of 1
      • The batteries should be on the right and left side in the keypad area, with two on each side.
      • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
      Ask FixBot
    7. TI-Nspire Battery Replacement: step 7, image 1 of 1
      • When reassembling your device, use four new batteries.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
7 other people completed this guide.
Clincy Cheung
223 Reputation
1 Guide authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
108 Guides authored
1 Guide Comment
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
nenene kldbfssm - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 120
All Time: 18,388
