Up to 20% off select tools
Connecting the Keypad
Views: 16K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
45
All Time:
15,639
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Very easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Connecting the Keypad, Keypad: step 1, image 1 of 2 Connecting the Keypad, Keypad: step 1, image 2 of 2
      • Turn the calculator over so the blue Texas Instruments logo is facing you.
      • Slide the blue cover downwards until it is completely removed from the calculator.
      Ask FixBot
    2. Connecting the Keypad: step 2, image 1 of 1
      • If the keypad is not already connected, skip the next 2 steps.
      • Turn the calculator over so the keypad is facing down.
      • Locate the sliding latch towards the bottom of the calculator.
      Ask FixBot
    3. Connecting the Keypad: step 3, image 1 of 2 Connecting the Keypad: step 3, image 2 of 2
      • Slide the latch to the right to release the keypad.
      • At the same time, pull the keypad downwards.
      Ask FixBot
    4. Connecting the Keypad: step 4, image 1 of 2 Connecting the Keypad: step 4, image 2 of 2
      • Take note of where the keypad and the calculator connect.
      Ask FixBot
    5. Connecting the Keypad: step 5, image 1 of 3 Connecting the Keypad: step 5, image 2 of 3 Connecting the Keypad: step 5, image 3 of 3
      • Slide the keypad directly into where it connects to the calculator until you hear a click. Readjust as necessary.
      Ask FixBot
    6. Connecting the Keypad: step 6, image 1 of 1
      • Press the "ON" button to make sure that the calculator turns on. If the calculator turns on correctly, you have properly inserted the keypad.
      Ask FixBot
If the keypad was inserted properly, the calculator should turn on without any errors.
Author
with
Mariel Sanchez
22 Reputation
2 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 45
All Time: 15,639
