OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to remove or replace the front shell (or front cover) on your Steam Deck OLED.
This procedure involves almost a complete disassembly, including removal of the screen! Know what you're getting yourself into.
Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your device.
You'll need replacement thermal paste, screen adhesive, speaker adhesives, and ambient light sensor adhesives to complete this repair.
Some photos in this guide may contain slight visual discrepancies, but won't affect the procedure.
Power down your Steam Deck and unplug any cables.
Measure 3Â mm from the tip and mark the opening pick with a permanent marker.
Prepare an iOpener and apply it to the top edge of the screen for one minute.
Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
Pull up on the suction handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
Pull up on the nub on the back of the suction handle to remove it from the screen.
Along the top and bottom edges, don't insert your pick deeper than 3Â mm (~1/8 of an inch) to avoid damaging the sensors, sensors cable, or screen cable.
Along the left and right edges, don't insert your pick deeper than 5Â mm (~1/5 of an inch) to avoid damaging the screen panel.
Rotate the pick so its flat edge is between the screen and frame.
Leave this pick inserted to prevent the adhesive from resealing.
Insert another pick in the top left corner.
Slide the pick toward the power button to separate the adhesive securing the top edge of the screen.
Insert another pick just below the right thumbstick.
Slide the pick to the bottom right corner to separate the right edge adhesive.
Leave the pick inserted to prevent the adhesive from resealing.
Insert another pick in bottom right corner along the bottom edge.
Slide the pick to the bottom left corner to separate the bottom edge adhesive.
Grip the two picks along the top edge.
Pry up to lift the top edge of the screen away from the frame until you can grab it.
Flip the screen over the bottom edge of the frame.
Prop up the screen with a small box or book roughly 2.5Â cm (~1Â inch) thick.
Use the point of a spudger or a clean fingernail to flip up the locking flap on the outside edge of the screen ZIF connector.
Tool used on this step:Tweezers$4.99
Use tweezers or your fingers to grip the screen cable pull tab and slide the cable straight out of its socket to disconnect it.
Tool used on this step:FixMat$31.41
Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
Slide your pick along the edge of the handle to release the clips securing it to the front shell.
Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
Remove the back cover.
Grip the battery cable pull tab, located to the left of the battery.
Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
During disassembly, skip the next three steps.
Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
Reconnect the interconnect cable ZIF connector.
Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
Use the point of a spudger to flip up the small locking flap on the left thumbstick ZIF connector.
Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
Use a spudger to flip up the small white locking flap on the left button board interconnect cable ZIF connector.
Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
Flip up the small black locking flap on the left thumbstick cable ZIF connector.
Slide the connector straight out of its socket to disconnect it.
Flip up the small locking flap on the D‑pad ZIF connector, located in the top right corner.
The pull tab on this connector may be labeled DPAD.
Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the previous one.
Lift the connector until its arms are free and slide it straight out to disconnect it.
Insert the point of your spudger under the neck of the haptics cable connector.
Gently pry up to disconnect it.
Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the haptics connector.
Use your T6 Torx driver to remove the four screws securing the left button board:
Two 5.9 mm‑long screws
One 3.8 mm‑long screw
One 4.9 mm‑long screw
Insert the point of your spudger between the bottom right corner of the button board and the frame.
Pry up until you can grab the button board with your fingers.
Remove the button board.
Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
Grip the edges of the thumbstick board and rotate it counterclockwise to clear the trigger.
Remove the thumbstick.
Place the flat end of a spudger onto the inside edge of the trigger's left clip.
Use your fingers to push the trigger toward the left as you wedge the spudger between the clip and the peg.
Use your spudger to pivot the trigger clip out, away, and up from the peg to unlatch it.
Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the left bumper assembly.
Grip the left arm of the bumper assembly and lift it off its alignment pegs.
Slide the assembly to the left to clear the tab on the right edge of the frame.
Remove the assembly.
Use tweezers to remove the D-pad.
Use tweezers to remove the Steam button membrane.
Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
Flip up the small black locking flap on the right thumbstick cable ZIF connector.
Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
The touchpad cable
The touchpad board cable
The action buttons and menu button cable
Use your T6 Torx driver to remove the four screws securing the right button board:
Insert the point of your spudger between the bottom left corner of the button board and the frame.
Grip the edges of the thumbstick board and rotate it clockwise to clear the trigger.
Place the flat end of a spudger onto the inside edge of the trigger's right clip.
Use your fingers to push the trigger toward the right as you wedge the spudger between the clip and the peg.
Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right bumper assembly.
Grip the right arm of the bumper assembly and lift it off the alignment pegs.
Slide the assembly to the right to clear the tab on the left edge of the frame.
Remove the action and menu buttons membrane from the frame.
Use tweezers to remove the four action buttons, A, B, X, and Y.
Use tweezers to remove the quick access button membrane.
Use tweezers to remove the menu button.
Use your T6 Torx driver to remove the four 5 mm‑long screws securing the right touchpad board.
Use your T6 Torx driver to remove the four 6 mm‑long screws securing the right touchpad.
Use your T6 Torx driver to remove the four 5 mm‑long screws securing the left touchpad board.
Use your T6 Torx driver to remove the four 6 mm‑long screws securing the left touchpad.
Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the top left and bottom left corners of the motherboard shield.
Lift the top edge of the motherboard shield up and flip it over to the right of the motherboard, over the battery.
Use an iOpener or hair dryer to soften the adhesive on the black sticker connecting the heat sink to the fan.
Slide the tip of an opening pick under one edge of the heat sink sticker.
Peel the sticker up until you can grab it with your fingers.
Gently remove the sticker from the heat sink and fan.
Use your T6 Torx driver to remove the three 3.3 mm‑long screws securing the heat sink.
Use the point of your spudger to flip up the small locking flap on the audio board ZIF connector in the upper right corner of the motherboard.
Use tweezers or your fingers to grip the cable's pull tab and pull it straight out of its socket to disconnect it.
Use your fingers or a spudger to gently lift the white locking tab on the audio board socket to release the cable.
Use tweezers or your fingers to pull the audio board cable out of its socket to disconnect it.
Insert the flat end of your spudger between the right speaker and the frame.
Slowly pry up the speaker to separate the adhesive securing it.
Insert the flat end of your spudger between the left speaker and the frame.
Place the motherboard shield back onto the motherboard to protect it during the rest of the repair.
Lay a soft, clean cloth on your work surface.
While holding the motherboard shield in place, flip over your Steam Deck OLED and lay it screen-side-down onto the cloth.
Insert the tip of an opening pick under the right-side ambient light sensor to separate it from the top right corner of the screen recess.
Lower your pick flat to the midframe and reinsert it under the metal tab located next to the ambient light sensor.
Slide your pick under the tab to separate it from the midframe.
Press the flat end of your spudger or your fingers through the bottom left cutout in the screen recess and separate the antenna from the front shell.
Repeat for the antenna in the bottom middle of the screen recess.
Flip your Steam Deck OLED back over and lay it screen-side-down.
Use your T6 Torx driver to remove the six 5.9 mm‑long screws securing the midframe to the front shell.
Rotate the device so the power button is closest to you.
Grip the bottom arms of the midframe and brace your other fingers against the front shell.
Use your fingers to pry the bottom edge of the midframe away from the front shell.
Continue holding up the bottom right arm of the midframe with one hand.
With your other hand, pry the top edge of the front shell (near the volume buttons) away from the midframe.
Lift the top right corner of the midframe away from the front shell until the headphone jack comes free of its cutout.
Repeat the previous step for the top left corner of the midframe, prying the front shell (near the power button) away from the midframe as you lift the midframe about half an inch (~1.25Â cm) up.
Insert the flat end of your spudger against the audio board cable in the cutout in the midframe.
Hold the cable's pull tab clear of the cutout and lift the midframe over the cable.
Flip the midframe over, screen-side-up.
Hook the top edge of your replacement front shell over the top edge of the midframe, aligning the buttons and ports with their cutouts.
Grip the right end of the audio board cable and thread it through its cutout in the midframe and over the motherboard. Use a spudger or tweezers to angle the cable away from the midframe as you thread it.
Ensure the left end of the audio board cable threads over the audio board and doesn't become trapped underneath.
Use your fingers to separate the metal tab securing the left-side ambient light sensor from the front shell.
Remove the ambient light sensors and audio board cable.
All that remains is the front shell.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
5 other people completed this guide.
3 Guide Comments
Steps 86, 87, 96 and 97 are not nessasary. I tried this and struggled for awhile, stopped before i damaged it. I went to the youtube guide by extreme rate, the maker of my replacement front shell. They say to pry on this part against the case to brake the glue and leaving it atrached to the main board support. That was much easier.
100% agree Colin. I found that lifting the silver metal tabs lift 90deg vertical from working surface and lifted out of insert mounts on the shell.
P.S. Unsure about how it affects the installation of wire. getting to that soon. I do not recommend this process as i am only 50% through it.
Stick with what you know. If you don't know, seek a source for answers and guidance that have been vetted.
