Sony Xperia Z5 Rear Glass Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
80
All Time:
1,524
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to remove the rear glass of the Sony Xperia Z5.
Opening the Sony Xperia Z5 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Sony Xperia Z5 Rear Glass Replacement, Back Cover: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Sony Xperia Z5 Rear Glass Replacement: step 2, image 1 of 2 Sony Xperia Z5 Rear Glass Replacement: step 2, image 2 of 2
      • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
      • Pull up the suction handle to generate a gap.
      • Insert an opening pick into the gap to further separate the rear glass from the phone assembly.
      • The adhesive of the Xperia Z5 is fairly weak and it is possible to remove the rear glass without the use of an opening pick. In case you‘re having trouble you can have a peek at the opening procedure of the Xperia Z4.
      Ask FixBot
    3. Sony Xperia Z5 Rear Glass Replacement: step 3, image 1 of 2 Sony Xperia Z5 Rear Glass Replacement: step 3, image 2 of 2
      • Carefully lift and remove the rear glass.
      • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape after cleaning the according areas with isopropyl alcohol (>90%).
Dominik Schnabelrauch
266,249 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 80
All Time: 1,524
