Sony Xperia Z4 Back Cover Removal
    1. Sony Xperia Z4 Back Cover Removal, Back Cover: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Sony Xperia Z4 Back Cover Removal: step 2, image 1 of 3 Sony Xperia Z4 Back Cover Removal: step 2, image 2 of 3 Sony Xperia Z4 Back Cover Removal: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom left corner.
      Ask FixBot
    3. Sony Xperia Z4 Back Cover Removal: step 3, image 1 of 2 Sony Xperia Z4 Back Cover Removal: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Sony Xperia Z4 Back Cover Removal: step 4, image 1 of 3 Sony Xperia Z4 Back Cover Removal: step 4, image 2 of 3 Sony Xperia Z4 Back Cover Removal: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Sony Xperia Z4 Back Cover Removal: step 5, image 1 of 2 Sony Xperia Z4 Back Cover Removal: step 5, image 2 of 2
      • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Sony Xperia Z4 Back Cover Removal: step 6, image 1 of 2 Sony Xperia Z4 Back Cover Removal: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Sony Xperia Z4 Back Cover Removal: step 7, image 1 of 2 Sony Xperia Z4 Back Cover Removal: step 7, image 2 of 2
      • Lift and remove the back cover.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      Ask FixBot
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape after cleaning the according areas with isopropyl alcohol (+90%).
Dominik Schnabelrauch
266,119 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,810 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 77
All Time: 2,376
