Sony Reader Wi-Fi PRS-T3 Battery Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
35
Past 30 Days:
125
All Time:
463
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide only goes over battery replacement, the disassembly and reassembly are covered in this prerequisite GUIDE
    1. Sony Reader Wi-Fi PRS-T3 Battery Replacement, When Your Battery fails to take a charge it's time to replace it.: step 1, image 1 of 1
      • A message like this lets you know it doesn't even have the power to turn off the screen... and if charging it doesn't work despite the lovely LED saying, "yes, I'm getting power" and the lightning bolt through the battery. Probably you need this guide.
      Ask FixBot
    2. Sony Reader Wi-Fi PRS-T3 Battery Replacement, To open the puppy:: step 2, image 1 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, To open the puppy:: step 2, image 2 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, To open the puppy:: step 2, image 3 of 3
      • Slip a guitar pick , fingernail, or what-have-you into the opening at the lower edge of the back cover and pry it up. This is the same thing you do to install a μSD (micro SD) card. Easy. Work your way about util you can remove the back cover
      Ask FixBot
    3. Sony Reader Wi-Fi PRS-T3 Battery Replacement, If you have a μSD card:: step 3, image 1 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, If you have a μSD card:: step 3, image 2 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, If you have a μSD card:: step 3, image 3 of 3
      • If you have a μSD card remove it, otherwise, skip this step.
      • Simply push the card deeper into the slot, it will pop-out enough for you to grasp and remove it.
      Ask FixBot
    4. Sony Reader Wi-Fi PRS-T3 Battery Replacement, That Black label is hiding screws...: step 4, image 1 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, That Black label is hiding screws...: step 4, image 2 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, That Black label is hiding screws...: step 4, image 3 of 3
      • You need to slip a sharp blade under one corner of the label and lift it enough to get a grip on it...
      • Then just peel it up, it's not flimsy and will peel easily. Then set it aside for later replacement.
      • Once you've done that, You'll see the battery, but you can't change it yet!
      Ask FixBot
    5. Sony Reader Wi-Fi PRS-T3 Battery Replacement, Now you need to follow this prerequisite guide:: step 5, image 1 of 2 Sony Reader Wi-Fi PRS-T3 Battery Replacement, Now you need to follow this prerequisite guide:: step 5, image 2 of 2
      • Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement
      • Once you get to the point where the back cover is removed and you can see the circuit board where the battery is connected, remove the black tape that's securing the wires and discard it (Doubtful it's capable of re-use)
      • (the masking tape is for holding down the new wires when we're done soldering the new battery in place)
      Ask FixBot
    6. Sony Reader Wi-Fi PRS-T3 Battery Replacement, Out with the old, in with the new.: step 6, image 1 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, Out with the old, in with the new.: step 6, image 2 of 3 Sony Reader Wi-Fi PRS-T3 Battery Replacement, Out with the old, in with the new.: step 6, image 3 of 3
      • Using your trusty (hot) soldering iron carefully touch each connection of the battery one at a time and pull the old wires off when the solder melts
      • Use a bit of flux and solder to solder each lead of the new battery in the correct position. From the top, Black, Red and White, just like what you removed.
      • Use a small piece of that masking tape to hold the new wires down.
      • If you haven't already done it stick the new battery in place, if you need to use a fresh double-sided adhesive tape. I didn't need to it stuck fine.
      • That's it, turn it over and it has probably resumed working normally except you'll need to re-do the initial set-up.
      • Put everything back the way you found it using the prerequisite guide if you need to.
      • On the one I fixed the little magnets fell out, I've no idea their function, but if yours fall out they go on the opposite side from the wi-fi antenna and stick to a tiny metal bar.
      • Lastly, sorry about no photos of the actual soldering work but I was using both hands for that and it's pretty simple, make the joints good, don't overheat or short anything and it's a piece of cake.
      Ask FixBot
Juan Garcia
10,385 Reputation
3 Guides authored
1 Guide Comment
Thank you John
Guenter Melchert - Reply Share
Past 24 Hours: 8
Past 7 Days: 35
Past 30 Days: 125
All Time: 463
