Sony FDL-220R Watchman Speaker Replacement
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: step 1, image 1 of 2 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: step 1, image 2 of 2
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
    Ask FixBot
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: step 2, image 1 of 2 Sony FDL-220R Watchman Speaker Replacement, Remove screws: step 2, image 2 of 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
    Ask FixBot
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: step 3, image 1 of 2 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: step 3, image 2 of 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
    Ask FixBot
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: step 4, image 1 of 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: step 4, image 2 of 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: step 4, image 3 of 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
    Ask FixBot
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: step 5, image 1 of 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: step 5, image 2 of 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
    Ask FixBot
Sam Putnam
484 Reputation
4 Guides authored
Baylor, Team 4-5, Williams Fall 2014 Member of Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 38
All Time: 536
