Sony FDL-220R Watchman Button Replacement
    1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: step 1, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: step 1, image 2 of 2
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      Ask FixBot
    2. Sony FDL-220R Watchman Button Replacement, Remove screws: step 2, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove screws: step 2, image 2 of 2
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Philips #00 screwdriver.
      Ask FixBot
    3. Sony FDL-220R Watchman Button Replacement, Remove back casing: step 3, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: step 3, image 2 of 2
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      Ask FixBot
    4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 1 of 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 2 of 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: step 4, image 3 of 3
      • Carefully grasp the entire circuit board.
      • Pull the circuit board off of the device's plastic casing.
      Ask FixBot
    5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: step 5, image 1 of 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: step 5, image 2 of 2
      • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
      • Buttons/switches should be simply resting in their slots on the device.
      • Remove all three buttons/switches.
      • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
      • If one of the buttons/switches is broken, simply replace it with a new one.
      • When replacing, make sure that the slot on the switches faces up.
      Ask FixBot
Sam Putnam
484 Reputation
4 Guides authored
Baylor, Team 4-5, Williams Fall 2014 Member of Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 582
