Sony FDL-220R Watchman Antenna Replacement
    1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: step 1, image 1 of 2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: step 1, image 2 of 2
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      Ask FixBot
    2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: step 2, image 1 of 2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: step 2, image 2 of 2
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Phillips #00 screwdriver.
      Ask FixBot
    3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: step 3, image 1 of 2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: step 3, image 2 of 2
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
      Ask FixBot
    4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: step 4, image 1 of 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: step 4, image 2 of 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: step 4, image 3 of 3
      • Locate the two metal tabs which are meant to hold the antenna in place.
      • Pry back the metal tabs with a spudger.
      • Hook the antenna into the metal tab.
      • Ensure that the antenna is fully enclosed in the metal tab.
      Ask FixBot
Sam Putnam
484 Reputation
4 Guides authored
Baylor, Team 4-5, Williams Fall 2014 Member of Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 28
Past 30 Days: 76
All Time: 880
