Sony α6500 Memory Card Reader Replacement
    1. Sony α6500 Memory Card Reader Replacement, Battery: step 1, image 1 of 1
      • Verify the camera is powered off by setting the switch to OFF.
      Ask FixBot
    2. Sony α6500 Memory Card Reader Replacement: step 2, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 2, image 2 of 2
      • Flip the camera upside down.
      • Slide the battery compartment lock to OPEN to unlock it.
      Ask FixBot
    3. Sony α6500 Memory Card Reader Replacement: step 3, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 3, image 2 of 2
      • Push the blue lever aside to release the battery.
      Ask FixBot
    4. Sony α6500 Memory Card Reader Replacement: step 4, image 1 of 1
      • Remove the released battery from the compartment.
      Ask FixBot
    1. Sony α6500 Memory Card Reader Replacement, Top Assembly: step 5, image 1 of 2 Sony α6500 Memory Card Reader Replacement, Top Assembly: step 5, image 2 of 2
      • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
      • Remove four 3 mm JIS 000 screws.
      • Remove one 3 mm JIS 00 screw.
      • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
      Ask FixBot
    2. Sony α6500 Memory Card Reader Replacement: step 6, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 6, image 2 of 2
      • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
      Ask FixBot
    3. Sony α6500 Memory Card Reader Replacement: step 7, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 7, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 7, image 3 of 3
      • Press the flash popup button on the back of the camera.
      • Remove one 5 mm JIS 00 screw from inside the flash compartment.
      • Remove one 4 mm JIS 00 screw.
      Ask FixBot
    4. Sony α6500 Memory Card Reader Replacement: step 8, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 8, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 8, image 3 of 3
      • To remove the top of the camera you must remove the back first.
      • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
      • Use the opening tool to pry off the small cover.
      • Remove two 2.5 mm JIS 00 screws from underneath the cover.
      • Remove a 5 mm JIS 00 screw from underneath the cover.
      Ask FixBot
    5. Sony α6500 Memory Card Reader Replacement: step 9, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 9, image 2 of 2
      • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
      • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
      Ask FixBot
    6. Sony α6500 Memory Card Reader Replacement: step 10, image 1 of 1
      • Remove four 4 mm JIS 0 screws from the bottom of the camera.
      Ask FixBot
    7. Sony α6500 Memory Card Reader Replacement: step 11, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 11, image 2 of 2
      • Flip the battery lock switch to open and open the battery compartment.
      • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
      • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
      Ask FixBot
    8. Sony α6500 Memory Card Reader Replacement: step 12, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 12, image 2 of 2
      • Use the plastic opening tool to begin prying off the back of the camera from the side.
      • Continue to loosen the back until you can open it from the bottom.
      Ask FixBot
    9. Sony α6500 Memory Card Reader Replacement: step 13, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 13, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Open the back of the camera.
      • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
      • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
      Ask FixBot
    10. Sony α6500 Memory Card Reader Replacement: step 14, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 14, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 14, image 3 of 3
      • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
      • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
      • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
      • Remove one 4 mm JIS 000 screw from the left side.
      Ask FixBot
    11. Sony α6500 Memory Card Reader Replacement: step 15, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 15, image 2 of 2
      • The last screws holding the top on can be accessed once the back of the camera is removed.
      • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
      Ask FixBot
    12. Sony α6500 Memory Card Reader Replacement: step 16, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 16, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 16, image 3 of 3
      • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
      Ask FixBot
    13. Sony α6500 Memory Card Reader Replacement: step 17, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 17, image 2 of 2
      • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
      Ask FixBot
    14. Sony α6500 Memory Card Reader Replacement: step 18, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 18, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 18, image 3 of 3
      • Use the plastic opening tool to gently lift up the shutter button assembly.
      • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
      • The shutter button will still be attached by one ribbon cable once the front grip is removed.
      Ask FixBot
    15. Sony α6500 Memory Card Reader Replacement: step 19, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 19, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 19, image 3 of 3
      • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
      • Remove one 3 mm JIS 00 screw from the side of the camera.
      Ask FixBot
    16. Sony α6500 Memory Card Reader Replacement: step 20, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 20, image 2 of 2
      • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
      Ask FixBot
    1. Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: step 21, image 1 of 3 Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: step 21, image 2 of 3 Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: step 21, image 3 of 3
      • From the top of the camera remove one 4mm JIS 00 screw.
      • Remove one 5mm JIS 00 screw and the plastic bushing around it.
      • Remove the viewfinder's protective cover.
      Ask FixBot
    2. Sony α6500 Memory Card Reader Replacement: step 22, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 22, image 2 of 2
      • Use the spudger to pry the light sensor off the side of the viewfinder.
      • When prying off the sensor, bend it out from the bottom.
      • Remove one 2.5mm JIS 000 screw on the side of the viewfinder to release it.
      Ask FixBot
    3. Sony α6500 Memory Card Reader Replacement: step 23, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 23, image 2 of 2
      • Lift the viewfinder out and flip up the tab to release the wire ribbon where it is connected to the motherboard.
      Ask FixBot
    1. Sony α6500 Memory Card Reader Replacement, Motherboard: step 24, image 1 of 3 Sony α6500 Memory Card Reader Replacement, Motherboard: step 24, image 2 of 3 Sony α6500 Memory Card Reader Replacement, Motherboard: step 24, image 3 of 3
      • Remove two 2.5mm JIS 00 screws from the left side and bottom of the copper shielding.
      • Remove two 2mm JIS 000 screws from the right side of the copper shielding.
      • Pull the entire copper shielding piece off.
      • When replacing the shielding, make sure to position the wire ribbon slot under the tabs designed to hold it down.
      Ask FixBot
    2. Sony α6500 Memory Card Reader Replacement: step 25, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 25, image 2 of 2
      • You have now accessed the motherboard. The next step is to remove all the wire ribbons attached to it.
      • Remove one 4mm JIS 00 screw holding down a plastic spacer on the bottom left of the motherboard.
      Ask FixBot
    3. Sony α6500 Memory Card Reader Replacement: step 26, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 26, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 26, image 3 of 3
      Buy
      • Use tweezers to carefully pull out the first wire ribbon on the left side of the motherboard.
      • Use the spudger to flip up the tab locking in the wire ribbons at the bottom of the motherboard, then pull them out with tweezers.
      Ask FixBot
    4. Sony α6500 Memory Card Reader Replacement: step 27, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 27, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 27, image 3 of 3
      • Carefully use tweezers to remove four wire ribbons on the right side of the motherboard.
      • Remove the last two wire ribbons on the top of the motherboard by flipping up the locking tab and pulling them out.
      • Pull the blue coaxial cable up off the board.
      Ask FixBot
    5. Sony α6500 Memory Card Reader Replacement: step 28, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 28, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 28, image 3 of 3
      • Remove one 4mm JIS 00 screw from the upper right of the motherboard and another from the far left.
      • Remove the plastic housing for the power and HDMI ports.
      Ask FixBot
    6. Sony α6500 Memory Card Reader Replacement: step 29, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 29, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 29, image 3 of 3
      • The flash capacitors connected to the yellow wire harness have dangerous amounts of stored charge. You must safely discharge them before continuing. Use a Capacitor Discharging Tool to do so.
      • Grasp the motherboard from the sides and lift it up. It is still connected by two wires on the bottom right side.
      • Pull the wire ribbon on the underside off with tweezers.
      • After you have discharged the capacitor, pull the yellow wire harness out using tweezers.
      Ask FixBot
    7. Sony α6500 Memory Card Reader Replacement: step 30, image 1 of 1
      • Disconnect the wire ribbon connecting the power port to the board.
      Ask FixBot
    1. Sony α6500 Memory Card Reader Replacement, Memory Card Reader: step 31, image 1 of 1
      • Unplug the small ribbon located underneath the ON/OFF button and detach the button assembly from the camera.
      Ask FixBot
    2. Sony α6500 Memory Card Reader Replacement: step 32, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 32, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 32, image 3 of 3
      • Remove one 2.5mm JIS 000 screw from the right side of the camera grip.
      • Remove a 4mm JIS 00 screw from the front of the grip and a 2.5mm JIS 00 screw from the left side.
      Ask FixBot
    3. Sony α6500 Memory Card Reader Replacement: step 33, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 33, image 2 of 2
      • Flip the black capacitor mount up and remove the 2.5mm JIS 00 screw located directly underneath it.
      Ask FixBot
    4. Sony α6500 Memory Card Reader Replacement: step 34, image 1 of 2 Sony α6500 Memory Card Reader Replacement: step 34, image 2 of 2
      • Carefully remove the small ribbon where the ON/OFF button used to be.
      • Remove the 4mm JIS 00 screw found directly underneath the small ribbon.
      Ask FixBot
    5. Sony α6500 Memory Card Reader Replacement: step 35, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 35, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 35, image 3 of 3
      • Remove the 5mm JIS 00 screw just to the left of the base of the battery compartment.
      • With this screw gone, loosen, but do not remove, the black plastic frame on top of the battery compartment.
      Ask FixBot
    6. Sony α6500 Memory Card Reader Replacement: step 36, image 1 of 3 Sony α6500 Memory Card Reader Replacement: step 36, image 2 of 3 Sony α6500 Memory Card Reader Replacement: step 36, image 3 of 3
      Buy
      • It may be a challenge to remove the SD card reader since it has to be maneuvered out from between other components which have not been removed.
      • Carefully loosen the silver battery compartment from the body of the camera.
      • Use tweezers to remove the sd card slot located adjacent to the battery compartment.
      Ask FixBot
Jackson Furie
859 Reputation
5 Guides authored
Cal Poly, Team S11-G5, Regan Fall 2019 Member of Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Members
82 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 71
All Time: 5,704
