Up to 20% off select tools
Skateboard Wheel Replacement
Views: 80K
View statistics:
Past 24 Hours:
8
Past 7 Days:
45
Past 30 Days:
217
All Time:
80,314
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This manual will show you how to correctly remove wheels, change bearings, and install new wheels onto your skateboard.
You may reuse old bearings, or purchase new ones.
    1. Skateboard Wheel Replacement, The skate board fix up: step 1, image 1 of 1
      • With a 13mm wrench, remove the axle nut located in the center of the wheel.
      • Set the axle nut aside, and remove the wheel.
      Ask FixBot
    2. Skateboard Wheel Replacement, Remove the Bearings: step 2, image 1 of 1
      • Position the wheel at the end of the axle.
      • To remove the bearings, gently pry the wheel at a downward angle.
      • Perform this prying process on both sides of the wheel.
      • A bearing spacer should fall out once the bearings are removed.
      Ask FixBot
    3. Skateboard Wheel Replacement: step 3, image 1 of 1
      • Position the new wheel on a flat surface.
      • Press the bearing into the hole of the new wheel.
      • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
      Ask FixBot
    4. Skateboard Wheel Replacement: step 4, image 1 of 1
      • Flip the wheel over.
      • Insert the bearing spacer into the back the wheel.
      Ask FixBot
    5. Skateboard Wheel Replacement: step 5, image 1 of 1
      • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
      • With the bearings in place, the wheel can be placed on the axle.
      Ask FixBot
    6. Skateboard Wheel Replacement: step 6, image 1 of 1
      • Slide one washer onto the axle.
      Ask FixBot
    7. Skateboard Wheel Replacement: step 7, image 1 of 1
      • Slide the wheel onto the axle.
      • The axle should go through both bearings and the bearing spacer.
      Ask FixBot
    8. Skateboard Wheel Replacement: step 8, image 1 of 1
      • Slide the second washer onto the axle on the outside of the wheel.
      Ask FixBot
    9. Skateboard Wheel Replacement: step 9, image 1 of 1
      • Tighten the axle nut firmly.
      • Do not over tighten. The wheel should spin freely.
      • Repeat steps 1-9 for the remaining wheels.
      Ask FixBot
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
9 other people completed this guide.
Author
with
Jared Stine
800 Reputation
3 Guides authored
Cal Poly, Team 6-32, Regan Fall 2012 Member of Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Members
60 Guides authored
3 Guide Comments
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - Reply Share
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - Reply Share
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - Reply Share
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 217
All Time: 80,314
