Up to 20% off select tools
How to Prevent Wheel Bite
Views: 20K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
109
All Time:
19,613
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
There are a number of ways that you can reduce the occurrence of wheel bite with your skateboard. All of these ways can be used separately or together depending on your preference and need. This guide will show you how to perform the three most fundamental methods in order of how they would be installed together. Keep in mind you can pick and choose any of these methods at your discretion.
    1. How to Prevent Wheel Bite, How to Prevent Wheel Bite: step 1, image 1 of 1
      • When it comes to preventing wheel bite you may want to add a riser. This will occur during the truck installation process. If you have not started this process, get to step 3 in the Truck Installation guide and return here for your next step.
      • Now that you are just about ready to install your trucks, simply place the riser onto the hardware before the trucks. Return to the Truck Installation guide to finish installing the trucks.
      Ask FixBot
    2. How to Prevent Wheel Bite: step 2, image 1 of 1
      • Once you have installed your trucks you can tighten your kingpin nut using a 9/16" wrench to prevent wheel bite.
      • Tightening your kingpin will limit your turning ability so that the wheels won't catch on the deck.
      Ask FixBot
    3. How to Prevent Wheel Bite: step 3, image 1 of 1
      • Another way to further prevent wheel bite is to replace the kingpin bushings with a harder ones. You will first want to remove the kingpin nut completely using your 9/16" wrench.
      Ask FixBot
    4. How to Prevent Wheel Bite: step 4, image 1 of 1
      • Remove the kingpin bushings from the kingpin.
      Ask FixBot
    5. How to Prevent Wheel Bite: step 5, image 1 of 1
      • Slide on your new harder kingpin bushings.
      Ask FixBot
    6. How to Prevent Wheel Bite: step 6, image 1 of 1
      • Place the washer back over your new kingpin bushing and thread on the kingpin nut to your preferred tightness. This harder bushing will make it harder to turn, preventing the wheels from hitting the deck on hard turns.
      Ask FixBot
To remove your risers, simply remove your trucks following the reverse directions of the Truck Installation guide. Follow steps of this guide in reverse to replace your old kingpin bushing.
5 other people completed this guide.
Author
with
Jared Stine
800 Reputation
3 Guides authored
Cal Poly, Team 6-32, Regan Fall 2012 Member of Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Members
60 Guides authored
1 Guide Comment
That's some mondo wheel bite on that board! :-P
Wesley Applequist - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 109
All Time: 19,613
