Up to 20% off select tools
Samsung WB35F Flash Capacitor Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
27
Past 30 Days:
121
All Time:
3,210
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will give user step by step instructions on how to replace the flash capacitor of the camera.
    1. Samsung WB35F Flash Capacitor Replacement, Rear Case: step 1, image 1 of 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: step 1, image 2 of 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: step 1, image 3 of 3
      • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
      • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
      Ask FixBot
    2. Samsung WB35F Flash Capacitor Replacement: step 2, image 1 of 2 Samsung WB35F Flash Capacitor Replacement: step 2, image 2 of 2
      • Using the spudger, and plastic opening tool open the casing of camera.
      Ask FixBot
    3. Samsung WB35F Flash Capacitor Replacement: step 3, image 1 of 3 Samsung WB35F Flash Capacitor Replacement: step 3, image 2 of 3 Samsung WB35F Flash Capacitor Replacement: step 3, image 3 of 3
      • Once you open the camera case, you will be able to work on any part of the camera.
      Ask FixBot
    1. Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: step 4, image 1 of 2 Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: step 4, image 2 of 2
      • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
      • Carefully take out the capacitor using the spudger.
      Ask FixBot
    2. Samsung WB35F Flash Capacitor Replacement: step 5, image 1 of 1
      • Disconnect the wire from battery and replace the old battery with new battery.
      • Connect the wires to new battery and put the battery back in terminal.
      • Connect the positive wire to the positive terminal of the battery and negative wire to the the negative terminal of the battery.
      Ask FixBot
Author
with
Sarmad Khan
549 Reputation
5 Guides authored
USF Tampa, Team 1-6, Tanski Winter 2015 Member of USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 121
All Time: 3,210
