Samsung SyncMaster 2443 Backlight Inverter Replacement
    1. Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 1 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 2 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 3 of 3
      • Remove the power cord before disassembly.
      • Remove the display stand by removing the two screws on the round plate on the back of the monitor.
      • Open up the back of the display (place it face down on a cloth to avoid scratches) by carefully releasing the latches using a screwdriver or opener tool.
      Ask FixBot
    2. Samsung SyncMaster 2443 Backlight Inverter Replacement, Remove metal cage containing PCBs: step 2, image 1 of 2 Samsung SyncMaster 2443 Backlight Inverter Replacement, Remove metal cage containing PCBs: step 2, image 2 of 2
      • The metal cage housing the PCBs is stuck to the backside of the LCD.
      • Carefully remove the adhesive strips, then release the cables to the LCD and front panel buttons.
      • Remove the SMPS PCB (switching mode power supply) by removing the screws around it.
      Ask FixBot
    3. Samsung SyncMaster 2443 Backlight Inverter Replacement, Desolder the transformer: step 3, image 1 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Desolder the transformer: step 3, image 2 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Desolder the transformer: step 3, image 3 of 3
      • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
      • Desolder the transformer from the power board. It has 6 pins on one side and 4 pins on the other.
      • Replace with a new transformer. (Model no. TM-09176)
      Ask FixBot
7 other people completed this guide.
Thomas Widmaier
2,263 Reputation
11 Guides authored
9 Guide Comments
Caution!
Myrra 12 V AC Transfor 5VA is not compatible with TM09176
Walter Holzwarth - Reply Share
Hi, I have the same issue with the same monitor. But in my case, the transformer has equal temperature on both sides. Is there any way for me to check if it’s really the transformer or something else?
One more thing, there is a high-pitched noise coming from the upper part of the screen (probably the backlight), after the screen goes dark again. Thanks!
Kristijan Žganec - Reply Share
High pitched noise is probably the resonance of a coil either the transformer or another inductor of the swtiching regulator circuit.
You could try and measure the inductance / resistance of the transformer (desolder first) and check if they match very closely.
Thomas Widmaier - Reply Share
I took some thermal images (using SeekTermal camera) from the power-supply board of this TV:
The rectangular black transformer TM-09176 (T301) gets 60°C at one side only. But the resistor R301 beside the transformer, gets nearly 100°C! This is maybe due to unregulated high current coming from the transformer? The rest of the board stays very cool.
Dumbo - Reply Share
Measure if there is any short circuit to ground with resistance or continuity mode around the resistor that gets hot.
Maby the CCFL Tube or wire is shorted ?
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 50
All Time: 14,451
