Tools
Spudger4.9
Introduction
Go to step 1 ↓Is your LCD stuck in place, cracked or unresponsive? Use this guide to remove the LCD assembly and make necessary repairs.
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Tool used on this step:Tweezers$4.99
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
