Up to 20% off select tools
Samsung NX Mini Disassembly
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
149
All Time:
5,397
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide gives you a look at the major components of the Samsung NX Mini and provides complete disassembly instructions.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
    1. Samsung NX Mini Disassembly, Battery: step 1, image 1 of 3 Samsung NX Mini Disassembly, Battery: step 1, image 2 of 3 Samsung NX Mini Disassembly, Battery: step 1, image 3 of 3
      • Orient the camera so the button panel and LCD are facing you.
      • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 2, image 1 of 2 Samsung NX Mini Disassembly: step 2, image 2 of 2
      • Push the blue trapdoor to the left to release the battery, and remove the battery.
      • There is no battery shown in this photo.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Front Case: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 4, image 1 of 1
      • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
      Ask FixBot
    3. Samsung NX Mini Disassembly: step 5, image 1 of 1
      • Remove the four 5 mm Phillips #00 screws from the lens assembly.
      Ask FixBot
    4. Samsung NX Mini Disassembly: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the metal lens mount by hand or with tweezers.
      • Be careful not to touch the sensor in the center of the lens assembly.
      Ask FixBot
    5. Samsung NX Mini Disassembly: step 7, image 1 of 1
      • Use tweezers to remove the inner metal ring.
      Ask FixBot
    6. Samsung NX Mini Disassembly: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
      Ask FixBot
    7. Samsung NX Mini Disassembly: step 9, image 1 of 2 Samsung NX Mini Disassembly: step 9, image 2 of 2
      • Use your hands to slowly pull the front casing away from the camera.
      • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Sensor: step 10, image 1 of 3 Samsung NX Mini Disassembly, Sensor: step 10, image 2 of 3 Samsung NX Mini Disassembly, Sensor: step 10, image 3 of 3
      Buy
      • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
      • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
      • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
      • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 11, image 1 of 2 Samsung NX Mini Disassembly: step 11, image 2 of 2
      • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
      Ask FixBot
    3. Samsung NX Mini Disassembly: step 12, image 1 of 3 Samsung NX Mini Disassembly: step 12, image 2 of 3 Samsung NX Mini Disassembly: step 12, image 3 of 3
      • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
      • Remove the battery compartment.
      Ask FixBot
    4. Samsung NX Mini Disassembly: step 13, image 1 of 2 Samsung NX Mini Disassembly: step 13, image 2 of 2
      • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
      Ask FixBot
    5. Samsung NX Mini Disassembly: step 14, image 1 of 1
      • Gently remove the sensor mount from the camera case.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Motherboard: step 15, image 1 of 2 Samsung NX Mini Disassembly, Motherboard: step 15, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 16, image 1 of 2 Samsung NX Mini Disassembly: step 16, image 2 of 2
      Buy
      • Use tweezers to disconnect the wifi antenna from the motherboard.
      Ask FixBot
    3. Samsung NX Mini Disassembly: step 17, image 1 of 3 Samsung NX Mini Disassembly: step 17, image 2 of 3 Samsung NX Mini Disassembly: step 17, image 3 of 3
      • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
      Ask FixBot
    4. Samsung NX Mini Disassembly: step 18, image 1 of 3 Samsung NX Mini Disassembly: step 18, image 2 of 3 Samsung NX Mini Disassembly: step 18, image 3 of 3
      • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
      Ask FixBot
    5. Samsung NX Mini Disassembly: step 19, image 1 of 2 Samsung NX Mini Disassembly: step 19, image 2 of 2
      • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
      • Gently pull the spudger back to slide the ribbon cable out of its connector.
      Ask FixBot
    6. Samsung NX Mini Disassembly: step 20, image 1 of 3 Samsung NX Mini Disassembly: step 20, image 2 of 3 Samsung NX Mini Disassembly: step 20, image 3 of 3
      • Disconnect the blue ribbon cable from the motherboard.
      • Insert the pointed end of a spudger into the hole in the top of the ribbon.
      • Gently pull the ribbon from the connector.
      Ask FixBot
    7. Samsung NX Mini Disassembly: step 21, image 1 of 1
      • Remove the motherboard from the camera.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Flash Assembly: step 22, image 1 of 3 Samsung NX Mini Disassembly, Flash Assembly: step 22, image 2 of 3 Samsung NX Mini Disassembly, Flash Assembly: step 22, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 23, image 1 of 2 Samsung NX Mini Disassembly: step 23, image 2 of 2
      • Remove the flash assembly by gently pulling it away from the case.
      • You may need to use a spudger to release some of the clips holding the assembly in place.
      • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Button Panel: step 24, image 1 of 1
      • Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 25, image 1 of 1
      Buy
      • Use tweezers to lift the button panel cover away from the case.
      Ask FixBot
    1. Samsung NX Mini Disassembly, LCD: step 26, image 1 of 1
      • Remove the 5 mm Phillips #00 screw in the top right corner of the LCD assembly.
      Ask FixBot
    2. Samsung NX Mini Disassembly: step 27, image 1 of 2 Samsung NX Mini Disassembly: step 27, image 2 of 2
      • Tilt and wiggle the LCD to remove it from the case.
      Ask FixBot
    1. Samsung NX Mini Disassembly, Samsung NX Mini Disassembly: step 28, image 1 of 1
      • You have disassembled the Samsung NX Mini!
      • The capacitor can be removed from the flash assembly by desoldering. Learn about soldering techniques here.
      Ask FixBot
6 other people completed this guide.
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
4 Guide Comments
Great! Do you have any experiences or suggestions to fix its 9-27 lens that will not auto focus?
Wang Duan - Reply Share
do you have any nx mini device software tricks or hacks? (Video time limit or no lens error or anything)
Teknoloji-Haber-Net - - Reply Share
Any experiences to change the LCD ?
Finti Utami - Reply Share
This camera could be so much better if Samsung adds flash with manual mode when using vintage lenses. Is there any way to get camera to fire flash?
If Samsung just added a toggle option on/off that would be great. If there was a way to control intensity of the flash then even better. It is standard on Nikon 1 camera.
Leo - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 149
All Time: 5,397
