Samsung NP900X4B SSD Hard Drive Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
72
All Time:
3,154
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
This guide will give a step by step walk through on how to replace the hard drive of a Samsung NP900X4B Laptop. Before replacing the hard drive make sure the device is unplugged and turned off as a safety step.
Tools
    1. Samsung NP900X4B SSD Hard Drive Replacement, SSD Hard Drive: step 1, image 1 of 1
      • Before begining you must remove the back panel of the laptop. The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
      • Once this is completed, use this image to locate the Hard Drive. It can be found in the upper left hand corner of the device.
      Ask FixBot
    2. Samsung NP900X4B SSD Hard Drive Replacement: step 2, image 1 of 2 Samsung NP900X4B SSD Hard Drive Replacement: step 2, image 2 of 2
      • Remove the two 2.5mm Phillips #000 screws at the top of the SSD.
      Ask FixBot
    3. Samsung NP900X4B SSD Hard Drive Replacement: step 3, image 1 of 2 Samsung NP900X4B SSD Hard Drive Replacement: step 3, image 2 of 2
      • Gently lift up from the top of the SSD card using a plastic opening tool.
      • Pull gently away from the drive slot located at the base of the SSD.
      • After removing the SSD memory chip, carefully insert the new SSD into the old slot. When completed, reinsert the two screws. Then, slowly remove the heat tape from the old SSD and apply to the new SSD.
      Ask FixBot
Bryton Lawrence
327 Reputation
2 Guides authored
1 Guide Comment
Excellent instruction. Thank you!
Sovfree - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 72
All Time: 3,154
