Samsung NP900X4B Battery Replacement
    1. Samsung NP900X4B Battery Replacement, Battery: step 1, image 1 of 2 Samsung NP900X4B Battery Replacement, Battery: step 1, image 2 of 2
      • Ensure computer is unplugged and powered down before continuing.
      • Remove the ten screws along the base using a Phillips #000.
      • Use a Plastic Opening Tool to pry open the base .
      Ask FixBot
    2. Samsung NP900X4B Battery Replacement: step 2, image 1 of 1
      • The battery is now unobstructed from your view.
      • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
      Ask FixBot
    3. Samsung NP900X4B Battery Replacement: step 3, image 1 of 2 Samsung NP900X4B Battery Replacement: step 3, image 2 of 2
      • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
      Ask FixBot
    4. Samsung NP900X4B Battery Replacement: step 4, image 1 of 1
      • Lift and pull out the battery.
      Ask FixBot
Nathan LeBlanc
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 65
All Time: 1,116
