Samsung Galaxy S25 Back Cover Replacement
    1. Samsung Galaxy S25 Back Cover Replacement, Safety precautions: step 1, image 1 of 2 Samsung Galaxy S25 Back Cover Replacement, Safety precautions: step 1, image 2 of 2
      • Let your Galaxy's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Completely power off your phone by holding the side key and volume down button and selecting Power off.
      Ask FixBot
    1. Samsung Galaxy S25 Back Cover Replacement, Cracked glass preparation: step 2, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Cracked glass preparation: step 2, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Cracked glass preparation: step 2, image 3 of 3
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. Samsung Galaxy S25 Back Cover Replacement, Heat the back cover: step 3, image 1 of 1
      • Adhesive secures the back cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the back cover for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the cover.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. Samsung Galaxy S25 Back Cover Replacement, Adhesive information: step 4, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Adhesive information: step 4, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Adhesive information: step 4, image 3 of 3
      • While the back cover heats, note the following about its adhesive:
      • The cover is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
      • Only insert your tool slightly under the cover near the cameras to avoid damaging them.
      Ask FixBot
    4. Samsung Galaxy S25 Back Cover Replacement, Apply a suction handle: step 5, image 1 of 2 Samsung Galaxy S25 Back Cover Replacement, Apply a suction handle: step 5, image 2 of 2
      • Apply a suction handle to the center of the back cover's bottom edge, as close to the edge as possible.
      Ask FixBot
    5. Samsung Galaxy S25 Back Cover Replacement, Insert an opening pick: step 6, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Insert an opening pick: step 6, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Insert an opening pick: step 6, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the back cover and frame.
      • Use the fingers of your lifting hand to hold the phone down, or steady the frame with your free hand—be careful, your phone may be hot.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    6. Samsung Galaxy S25 Back Cover Replacement, Separate the bottom edge adhesive: step 7, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the bottom edge adhesive: step 7, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the bottom edge adhesive: step 7, image 3 of 3
      • If the back cover feels stuck at any point when separating the adhesive, apply heat to the area and try again.
      • Slide the opening pick along the bottom edge to separate the adhesive.
      Ask FixBot
    7. Samsung Galaxy S25 Back Cover Replacement, Separate the right edge adhesive: step 8, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the right edge adhesive: step 8, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the right edge adhesive: step 8, image 3 of 3
      • Slide the opening pick around the bottom right corner and up the right edge to separate the adhesive.
      Ask FixBot
    8. Samsung Galaxy S25 Back Cover Replacement, Separate the top edge adhesive: step 9, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the top edge adhesive: step 9, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the top edge adhesive: step 9, image 3 of 3
      • In the next two steps, only insert the pick slightly (a few millimeters) near the cameras to avoid damaging them.
      • Slide the opening pick around the top right corner and along the top edge to separate the adhesive.
      Ask FixBot
    9. Samsung Galaxy S25 Back Cover Replacement, Separate the left edge adhesive: step 10, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the left edge adhesive: step 10, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Separate the left edge adhesive: step 10, image 3 of 3
      • Slide the opening pick around the top left corner and down the left edge to separate the adhesive.
      Ask FixBot
    10. Samsung Galaxy S25 Back Cover Replacement, Remove the back cover: step 11, image 1 of 3 Samsung Galaxy S25 Back Cover Replacement, Remove the back cover: step 11, image 2 of 3 Samsung Galaxy S25 Back Cover Replacement, Remove the back cover: step 11, image 3 of 3
      • Use the suction handle to lift and remove the back cover.
      • If the cover still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Check your rear cameras for any smudges and gently wipe them with a clean, lint–free cloth if necessary.
      • Your replacement back cover adhesive will be applied to either the frame or the back cover. Use cutouts and contours to see where it lines up best. If it matches the back cover, follow this guide. If it matches the frame, use this guide.
      Ask FixBot
Spencer Day
206,480 Reputation
1,266 Guides authored
1 Guide Comment
Why there is no guide how to put it back? And is there no back cover n
water resistance adhesive for the Samsung s25 for sale?
Michael Jonathan - Reply Share
Past 24 Hours: 21
Past 7 Days: 128
Past 30 Days: 625
All Time: 2,940
