Samsung Galaxy S21 Ultra Back Cover Replacement
    1. Samsung Galaxy S21 Ultra Back Cover Replacement, Heat the back cover: step 1, image 1 of 1
      • Unplug and power off your phone before you begin.
      • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S21 Ultra Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Samsung Galaxy S21 Ultra Back Cover Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy S21 Ultra Back Cover Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S21 Ultra Back Cover Replacement: step 4, image 1 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 4, image 2 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the right edge of your phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S21 Ultra Back Cover Replacement: step 5, image 1 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 5, image 2 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 5, image 3 of 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick underneath the top right corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy S21 Ultra Back Cover Replacement: step 6, image 1 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 6, image 2 of 3 Samsung Galaxy S21 Ultra Back Cover Replacement: step 6, image 3 of 3
      • Insert a fifth opening pick underneath the top left corner.
      • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
      • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
      Ask FixBot
    7. Samsung Galaxy S21 Ultra Back Cover Replacement, Remove the back cover: step 7, image 1 of 2 Samsung Galaxy S21 Ultra Back Cover Replacement, Remove the back cover: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
14 other people completed this guide.
Dominik Schnabelrauch
263,708 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
3 Guide Comments
Why would the adhesive only provide water resistance but not ingress protection? Is it inferior to OEM?
Luke Goodall - Reply Share
Is replacing the glass over the cameras a similar process, or can that be done without removing the back plate?
Stan Petersona - Reply Share
Do you have to transfer the flash, metal back plate, aluminum tape and camera gaskets like the cheap replacements or does this OEM Samsung part come with all that pre-installed?
Adam Skuderin - Reply Share
Past 24 Hours: 21
Past 7 Days: 128
Past 30 Days: 710
All Time: 46,060
