Samsung Galaxy A3 Display / LCD Replacement
    1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: step 1, image 1 of 1
      • Heat up the edges of the display with a heat gun or iPad opener.
      Ask FixBot
    2. Samsung Galaxy A3 Display / LCD Replacement: step 2, image 1 of 2 Samsung Galaxy A3 Display / LCD Replacement: step 2, image 2 of 2
      • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
      • Watch out for the ear speaker, camera and light sensor on the top of the phone.
      • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
      • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
      Ask FixBot
    3. Samsung Galaxy A3 Display / LCD Replacement: step 3, image 1 of 2 Samsung Galaxy A3 Display / LCD Replacement: step 3, image 2 of 2
      • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
      • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
      Ask FixBot
    4. Samsung Galaxy A3 Display / LCD Replacement: step 4, image 1 of 1
      • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
      • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
      • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
47 other people completed this guide.
Harvey
6,450 Reputation
10 Guides authored
6 Guide Comments
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - Reply Share
It’s been mentioned in step 2
Siamak - Reply Share
nice man really cool staff
Shelton Chiuswa - Reply Share
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - Reply Share
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 96
All Time: 48,205
