Samsung A3 2016 Model - A310F Display / LCD Replacement
    1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: step 1, image 1 of 1
      • Remove the SIM tray from the phone.
      Ask FixBot
    2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: step 2, image 1 of 1
      • Use a heat gun or iOpener to heat the back of the phone.
      • Insert a spudger or thin bladed tool between the batery cover and frame.
      • Slide all the way around to release the adhesive holding the cover.
      • The battery cover is also glass and can break if too much pressure is applied when removeing.
      Ask FixBot
    3. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 3, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 3, image 2 of 2
      • Remove all 16 screws from the housing
      Ask FixBot
    4. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 4, image 1 of 1
      • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
      • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
      Ask FixBot
    5. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 5, image 1 of 1
      • Remove the Philips screw securing the mainboard.
      • Remove the cable attached to the mainboard
      • Disconnect the display and camera connectors from the mainboard
      Ask FixBot
    6. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 6, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 6, image 2 of 2
      • Disconnect the daughter board from the mainboard
      Ask FixBot
    7. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 7, image 1 of 1
      • Using a heatgun, heat the front of the display.
      • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
      • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
      Ask FixBot
    8. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 1 of 3 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 2 of 3 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 3 of 3
      • Reattach the daughter board connector to the mainboard.
      • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
      • Re-connect the display connector, camera and cable to the mainboard.
      • Screw the mainboard to the frame
      Ask FixBot
    9. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 9, image 1 of 1
      • Turn the phone on and test the display before removing the adhesive on the back of the display.
      • If everything works, remove the adhesive and attach the display to the plastic frame.
      • Push the display into the metal housing so it fits snugly.
      Ask FixBot
    10. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 10, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 10, image 2 of 2
      • Replace the 16 screws that were removed in step 3.
      • Replace the battery cover and you are done.
      Ask FixBot
5 other people completed this guide.
Harvey
6,450 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 82
All Time: 4,452
