Up to 20% off select tools
SSD
Views: 2.8K
View statistics:
Past 24 Hours:
28
Past 7 Days:
242
Past 30 Days:
1,214
All Time:
2,800
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
SSD
Introduction
Go to step 1 ↓
MacBook Pro A1708 SSD Removal & Replacement Guide
This guide explains how to remove and replace the SSD in the MacBook Pro 13-inch A1708 (2016–2017). The A1708 is the non-Touch Bar model with function keys and has a removable SSD.
Before starting, shut down your MacBook, unplug all cables, and work on a clean, static-free surface. Keep track of screws because they vary in size. A magnetic mat is recommended.
🛠️ Tools Needed
  • Pentalobe 1.2 mm screwdriver – bottom case screws
  • Torx T5 screwdriver – SSD screw
  • Plastic opening tools – safely lift the bottom cover
  • Tweezers – small screws/connectors
⚠️ Check SSD Compatibility
The A1708 uses a proprietary Apple PCIe 3.0 SSD. Common capacities are 128GB, 256GB, 512GB, and 1TB.
There are two 256GB SSD variants, and some may not work with the Mid-2017 A1708. Check the SSD's model/serial information before purchasing.
💾 Apple OEM SSD Options
128GB
256GB
You can also buy the SSD directly from iFixit link in guide parts section
🔄 NVMe Upgrade Option
Instead of buying an Apple OEM SSD, you can use an NVMe SSD with an A1708-compatible adapter. This can be a cheaper way to increase storage.
A1708 NVMe Adapter:
⚠️ Important
This guide applies specifically to the A1708 MacBook Pro with function keys. Later MacBook Pro models use soldered storage and cannot have their SSD replaced in the same way.
Always verify the exact MacBook model and SSD compatibility before purchasing parts.
    1. SSD, Disable Auto Boot (This step is not needed if you don't have macOS installed): step 1, image 1 of 3 SSD, Disable Auto Boot (This step is not needed if you don't have macOS installed): step 1, image 2 of 3 SSD, Disable Auto Boot (This step is not needed if you don't have macOS installed): step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter.
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    2. SSD, Gather Tools: step 2, image 1 of 1
      • You’ll need specific screwdrivers and opening tools to safely disassemble the MacBook.
      • Screwdriver set
      • Suction cup
      • Pentalobe 1.2mm screwdriver
      • Tweezers
      • Magnetic mat (recommended)
      Ask FixBot
    3. SSD, Remove Bottom Cover: step 3, image 1 of 3 SSD, Remove Bottom Cover: step 3, image 2 of 3 SSD, Remove Bottom Cover: step 3, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use Your P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    4. SSD: step 4, image 1 of 3 SSD: step 4, image 2 of 3 SSD: step 4, image 3 of 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      Ask FixBot
    5. SSD: step 5, image 1 of 3 SSD: step 5, image 2 of 3 SSD: step 5, image 3 of 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      Ask FixBot
    6. SSD: step 6, image 1 of 3 SSD: step 6, image 2 of 3 SSD: step 6, image 3 of 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      Ask FixBot
    7. SSD: step 7, image 1 of 3 SSD: step 7, image 2 of 3 SSD: step 7, image 3 of 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • It may help to pull first at one corner, then the other.
      • This may require a lot of force.
      Ask FixBot
    8. SSD: step 8, image 1 of 1
      • Remove the lower case.
      Ask FixBot
    9. SSD, Battery Connector: step 9, image 1 of 2 SSD, Battery Connector: step 9, image 2 of 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      Ask FixBot
    10. SSD: step 10, image 1 of 2 SSD: step 10, image 2 of 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector
      Ask FixBot
    11. SSD: step 11, image 1 of 2 SSD: step 11, image 2 of 2
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      Ask FixBot
    12. SSD: step 12, image 1 of 2 SSD: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    13. SSD: step 13, image 1 of 1
      • Fold the battery board data cable back and out of the way.
      Ask FixBot
    14. SSD: step 14, image 1 of 1
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    15. SSD: step 15, image 1 of 2 SSD: step 15, image 2 of 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      Ask FixBot
    16. SSD, Remove SSD: step 16, image 1 of 2 SSD, Remove SSD: step 16, image 2 of 2
      • The removable SSD can now be accessed.
      • Locate SSD module
      • Unscrew retaining screw with Torx T5
      • Gently slide SSD out of connector
      Ask FixBot
    17. SSD, Disassembly complete: step 17, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your MacBook Pro 13" Function Keys 2017
      • For the Apple SSD reassemble see step 18
      • For The NVMe SSD reassemble see steps 19-20-21
      Ask FixBot
    18. SSD, Install the Apple SSD: step 18, image 1 of 2 SSD, Install the Apple SSD: step 18, image 2 of 2
      • Using Your T5 Screwdriver screw the 2 screws by the SSD (Marked by red)
      Ask FixBot
    19. SSD, Choose and Verify the Right Size SSD: step 19, image 1 of 2 SSD, Choose and Verify the Right Size SSD: step 19, image 2 of 2
      • Form Factor: You must use an M.2 2242 (or 2230) size NVMe SSD. Standard 2280 drives are too long and will not fit inside the A1708 enclosure without hitting components.
      • Recommended Drives: Popular stable, lower-heat choices include the Sabrent Rocket Nano 2242 or Toshiba XG5.
      • 1st Image showing M.2 NVMe SSD showing edge connector pins. Source: VitaliyPozdeyev / Getty Images
      • 2nd image shows NVMe ssd adapter screenshot from amazon link https://tinyurl.com/3maxzx62
      Ask FixBot
    20. SSD, Install the Combined Adapter and SSD into the Logic Board: step 20, image 1 of 1
      • Ensure the battery remains disconnected (the battery cable should be pulled loose and the plastic tab/metal bracket kept safe).
      • Hold the assembled adapter-and-SSD unit so that the gold connector pins are facing upwards (or matching the orientation of the original drive).
      • Insert the adapter straight into the logic board's proprietary SSD socket, pushing it firmly and evenly until it seats completely.
      • Fasten the SSD/adapter in place using the original T5 Torx screws on either side.
      • Reapply any black protective tape or thermal cover if applicable.
      Ask FixBot
    21. SSD: step 21, image 1 of 2 SSD: step 21, image 2 of 2
      • Lower the connector low enough so that it stays in its socket
      Ask FixBot
    22. SSD: step 22, image 1 of 1
      • Use a T5 Torx driver to put the 3.7 mm pancake screw back which secures the battery power connector.
      Ask FixBot
    23. SSD: step 23, image 1 of 1
      • Unfold the battery board data cable back into place
      Ask FixBot
    24. SSD: step 24, image 1 of 1
      • Reconnect the battery board data cable by sliding it back into its socket
      Ask FixBot
    25. SSD: step 25, image 1 of 1
      • Put the lower case.
      • Slide the lower case firmly toward the rear of the MacBook (toward the hinge area) until the internal clips snap back into place.
      • Use your P5 Pentalobe driver to reinstall and tighten the six screws securing the lower case.
      • Two 6.2 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      • Open the display, power on your MacBook, and plug in the power adapter.
      Ask FixBot
      • If you have another mac you can create the installer by going to this link https://support.apple.com/en-us/102662 https://support.apple.com/en-us/101578
      • if you have a windows PC (10 or 11) you can download the installer using GibMacOS https://github.com/corpnewt/gibmacos
      • and if you are using the windows method after it finish's downloading download transmac free trail https://www.acutesystems.com/dl_tmac and right click your usb drive and select restore from disk image select the installassistant.pkg
      • the latest macOS version this MacBook Pro 13" Function Keys 2017 supports is macOS ventura 13
      • boot from the usb drive my holding option at startup and select install macOS (version name) and choose your language
      • go to disk unity and press cmd+2 and click the ssd and hit erase and put the file system to APFS and name to macintosh HD and hit erase then quit disk unity cmd+Q and open install macOS (version name) and install it (this may take quite a while)
      Ask FixBot
You’ve now successfully removed and replaced the SSD in your MacBook Pro 13" A1708 (2017). By carefully following the steps and keeping track of screws and connectors, your MacBook should boot up with the new drive ready for macOS installation or migration.
To reassemble your device, follow the Above instructions in reverse order.
  • Take your e-waste to an R2 certified recycler or an e-Stewards certified recycler.
  • These facilities ensure safe handling of hazardous materials, secure data destruction, and environmentally responsible recycling.
  • This way, you protect the environment, keep toxic materials out of landfills, and ensure your data is securely destroyed.
Remember to reinstall macOS or restore from backup after the upgrade. If you’re unsure about compatibility, double-check the SSD part number against your MacBook’s EMC code (3164 for 2017).
With the right tools and patience, upgrading your SSD can extend the life of your MacBook and give you the storage space you need.
Shreyas vuyyuru
288 Reputation
16 Guides authored
1 Guide Comment
Great thank you
Soufiane Ouakif Business - Reply Share
Past 24 Hours: 28
Past 7 Days: 242
Past 30 Days: 1,214
All Time: 2,800
