Up to 20% off select tools
How to Disable Auto Boot
Views: 222K
View statistics:
Past 24 Hours:
46
Past 7 Days:
303
Past 30 Days:
1,668
All Time:
221,773
Comments: 48
19 comments on steps, 29 guide comments.
Go to guide comments
Completed: 78
78 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Auto Boot feature powers on your laptop as soon as you open the lid, so it should be disabled before undertaking certain repairs. Auto Boot can be found on 2016 (and newer) MacBook Pros and 2017 (and newer) 12" Retina MacBooks.
This guide will walk you through the process of disabling Auto Boot, and then re-enabling it when your repair is complete.
Note: Disabling Auto Boot may not work on Apple’s newer ARM-based M series MacBooks released in late 2020 and later. At this time, we don’t know any procedure for disabling Auto Boot on devices equipped with Big Sur v11.1 or later.
    1. How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 1 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 2 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 3 of 3
      • Power on your Mac and launch Terminal.
      • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
      Ask FixBot
    2. How to Disable Auto Boot: step 2, image 1 of 2 How to Disable Auto Boot: step 2, image 2 of 2
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return].
      • Your [return] key may also be labeled ⏎ or [enter].
      • If you are prompted for an administrative password, type the password and press [return].
      • Your password will not be displayed in Terminal.
      Ask FixBot
    3. How to Disable Auto Boot: step 3, image 1 of 1
      • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
      • Remember, you must still disconnect the battery before servicing internal components.
      Ask FixBot
    4. How to Disable Auto Boot: step 4, image 1 of 3 How to Disable Auto Boot: step 4, image 2 of 3 How to Disable Auto Boot: step 4, image 3 of 3
      • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
      • sudo nvram AutoBoot=%03
      • Press [return].
      • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
      Ask FixBot
Congrats! You're done.
78 other people completed this guide.
Author
with
Jeff Suovanen
455,865 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
29 Guide Comments
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Reply Share
You change the your user/Homefolder name
Ben Capehart - Reply Share
You do not need to change it for the command to work. But if you really do want to for a different reason, rename your home folder name.
Junaayd Shaikh - Reply Share
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Reply Share
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Reply Share
Past 24 Hours: 46
Past 7 Days: 303
Past 30 Days: 1,668
All Time: 221,773
