Up to 20% off select tools
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
100
All Time:
1,585
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the reset button and/or power switch get stuck or physically broken, they can be replaced using Phillips #0 and #2 screwdrivers.
    1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 3 of 3
      • With the console on its top. Remove the four 12 mm Phillips #2 screws.
      • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
      • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
      • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
      Ask FixBot
    2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 3 of 3
      • Remove the one 6 mm Phillips #0 screw.
      • Lift the top case.
      • This step allows easy button access and prevents accidental damage.
      Ask FixBot
    3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
      • Make sure you pinch both tabs simultaneously, or the button will not pop out.
      Ask FixBot
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Author
with
Truong Vo
324 Reputation
3 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 100
All Time: 1,585
