Retro-Bit Retro Duo Circuit Board Replacement
    1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
      • With the console on its top, remove the four 12 mm Phillips #2 screws.
      • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
      • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
      • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
      Ask FixBot
    2. Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 3 of 3
      • Remove the one 6 mm Phillips #0 LED circuit board screw.
      • Lift the top case and set aside.
      Ask FixBot
    3. Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 3 of 3
      • Remove the 11 screws holding the circuit boards and ports in place.
      • Six 11 mm Phillips #2 holding the circuit boards.
      • Three 12 mm Phillips #2 screws holding the controller ports.
      • Two 7 mm Philllips #2 screws holding the back ports
      Ask FixBot
    4. Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 3 of 3
      • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
      • Make sure to lift the circuit board completely out of the bottom case.
      • To avoid damage, do not to touch the top or bottom faces of the circuit board.
      Ask FixBot
Truong Vo
324 Reputation
3 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
60 Guides authored
1 Guide Comment
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 41
All Time: 3,285
