Up to 20% off select tools
Replacing an Invisible Zipper
Views: 15K
View statistics:
Past 24 Hours:
8
Past 7 Days:
45
Past 30 Days:
240
All Time:
15,112
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Breaking the invisible zipper of your fancy cocktail dress or everyday skirt doesn't need to be a tragic affair anymore. Following this guide will let you easily replace an invisible zipper and bring new life to the outfit gathering dust in the back of your closet. You will need a sewing machine and basic knowledge of how to operate it for this guide.
    1. Replacing an Invisible Zipper, Invisible Zipper: step 1, image 1 of 3 Replacing an Invisible Zipper, Invisible Zipper: step 1, image 2 of 3 Replacing an Invisible Zipper, Invisible Zipper: step 1, image 3 of 3
      • Prepare sewing machine with its compatible invisible zipper foot.
      • Thread the needle thread through the invisible zipper foot hole.
      • Pull the needle thread through the zipper foot hole.
      Ask FixBot
    2. Replacing an Invisible Zipper: step 2, image 1 of 3 Replacing an Invisible Zipper: step 2, image 2 of 3 Replacing an Invisible Zipper: step 2, image 3 of 3
      • Locate the stitch lines of where the broken zipper was sewn on both sides of your garment.
      • Use a seam ripper to carefully rip out both of the stitching lines.
      • How to Rip a Seam
      • Make sure to not cut through the fabric.
      • Remove old invisible zipper.
      Ask FixBot
    3. Replacing an Invisible Zipper: step 3, image 1 of 2 Replacing an Invisible Zipper: step 3, image 2 of 2
      • Turn the skirt inside out.
      • Place the replacement invisible zipper on the table, with the teeth side pointing up and the zipper pull facing down.
      • Unzip the invisible zipper. Line up the left side of the tape of the invisible zipper with the left side of your fabric.
      • The zipper teeth should 1/8" away from the edge of the fabric.
      Ask FixBot
    4. Replacing an Invisible Zipper: step 4, image 1 of 2 Replacing an Invisible Zipper: step 4, image 2 of 2
      • Pin the tape of the zipper to your garment's fabric perpendicular to the invisible zipper.
      Ask FixBot
    5. Replacing an Invisible Zipper: step 5, image 1 of 2 Replacing an Invisible Zipper: step 5, image 2 of 2
      • Place the teeth of the left side of the zipper into the right side of the invisible zipper foot.
      • When repeating on the opposite side of the zipper, place the teeth of the right side of the zipper on the left side of the invisible zipper foot.
      Ask FixBot
    6. Replacing an Invisible Zipper: step 6, image 1 of 3 Replacing an Invisible Zipper: step 6, image 2 of 3 Replacing an Invisible Zipper: step 6, image 3 of 3
      • Sew a straight line carefully, removing pins as you go.
      • Repeat Steps 5-8 on the right side of your garment.
      Ask FixBot
    7. Replacing an Invisible Zipper: step 7, image 1 of 3 Replacing an Invisible Zipper: step 7, image 2 of 3 Replacing an Invisible Zipper: step 7, image 3 of 3
      • Turn the skirt right-side out again, so you don't see the zipper teeth.
      • Rotate the fabric so the zipper foot is perpendicular to the zipper tape.
      • Position the zipper foot on top of the fabric 1/8th of an inch from where the zipper tape meets the garment.
      • Sew back and forth at least 6 times to seal the end.
      • This ensures that the zipper tab does not come off when you zip it up.
      • Flip garment over to see the stitch line you just made. Cut off excess zipper tape.
      Ask FixBot
    8. Replacing an Invisible Zipper: step 8, image 1 of 3 Replacing an Invisible Zipper: step 8, image 2 of 3 Replacing an Invisible Zipper: step 8, image 3 of 3
      • Pull up your newly replaced zipper.
      • Be proud of yourself! You've just replaced an invisible zipper!
      Ask FixBot
2 other people completed this guide.
Author
with
Katie Woo
125 Reputation
1 Guide authored
UC Davis, Team S3-G2, Coad Spring 2017 Member of UC Davis, Team S3-G2, Coad Spring 2017
UCD-COAD-S17S3G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 240
All Time: 15,112
