Up to 20% off select tools
How to Rip a Seam
Views: 29K
View statistics:
Past 24 Hours:
9
Past 7 Days:
60
Past 30 Days:
305
All Time:
28,645
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
How to Rip a Seam
Introduction
Go to step 1 ↓
Knowing how to rip a seam is essential for basic sewing and clothing repair. Whether you want to make alterations, replace a zipper, or fix a sewing mishap, ripping the seam properly will make the changes nearly invisible.
Return to the Patagonia Care & Repair homepage.
    1. How to Rip a Seam, How to Rip a Seam: step 1, image 1 of 2 How to Rip a Seam, How to Rip a Seam: step 1, image 2 of 2
      • Slip the sharp end of the seam ripper through a single stitch in the seam you want to remove.
      • Be sure your seam ripper goes through only the stitch, not the fabric, or you could puncture/tear the fabric.
      Ask FixBot
      • Slide the seam ripper forward, bringing the stitch into the crux of the seam ripper's fork and onto the blade.
      • Gently push the seam ripper forward, cutting the thread.
      • Rely on the blade to do the work. Do not apply a lot of force, as the seam ripper can slip and puncture the fabric.
      Ask FixBot
    2. How to Rip a Seam: step 3, image 1 of 1
      • You can use the method described in steps 1 and 2 to completely rip any seam. However, if you have a seam that binds two pieces of fabric, it is easier to rip the seam using the method described in step 4, below.
      • In order to use the method in Step 4, you need to remove the first few stitches of the seam using the method we already described in Step 1. Removing these stitches enables you to separate the two pieces of fabric and use the seam ripper on the stitches that hold them together.
      • Using the method below also helps prevent accidental puncturing of the garment.
      Ask FixBot
    3. How to Rip a Seam: step 4, image 1 of 2 How to Rip a Seam: step 4, image 2 of 2
      • Separate the two pieces of fabric held together by your seam.
      • Bring the sharp end of the seam ripper between the two pieces of fabric.
      • Slip the sharp end of the seam ripper beneath one of the stitches. Be careful to avoid catching the fabric.
      Ask FixBot
      • Slide the seam ripper forward. Bring the thread into the crux of the fork and onto the blade.
      • Gently push the seam ripper forward again, cutting the thread.
      • Continue working, stitch by stitch, until the seam has been removed. Take your time, being careful not to damage the fabric.
      • Remove all of the loose threads from the ripped seam to prevent tangling when you resew the seam.
      Ask FixBot
Finish Line
6 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 305
All Time: 28,645
