Replace Fairphone 3 screen (not the display module)
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
86
All Time:
101
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The display module as described elsewhere on this site (Fairphone 3 Display Module Replacement) has been out of stock for some time now. Yet the 'screen module' is still available on ebay, but - as noted in the comments - there is no manual for replacing just the screen. I can testify it is not an easy procedure and only adviseable if the screen is so severely damaged that the phone is unuseable.
I forgot to take photographs so I'll try to describe it in detail.
WARNING: the procedure will break the old screen in a zillion pieces!
NEEDED extra: glue. I used a 'rubber repair' glue which stays 'rubbery', just as the glue I found in my phone.
      • Follow steps 1-9 from Fairphone 3 Display Module Replacement
      • You now have the 'display module' which in fact consists of the screen module proper and a kind of plastic 'cover', also containing a loudspeaker. Separating the screen from the plastic 'cover' thingy is the job to be done and as they are firmly glued together it can not be done without breaking the old screen.
      Ask FixBot
      • At the back of the display module you'll see a small metal rectangle. This is a protective cap which can, without much force, be removed by pulling (or pushing) it straight upwards with any small tool. Note that the cap is held in place with tiny claws on 3 sides.
      Ask FixBot
      • Under the metal cap you'll recognise the connector as attached to the screen module you bought. (You may want to take a picture here.) To disconnect, pull it straight up (and of course be careful to avoid touching contacts).
      Ask FixBot
      • Turn the module over; around the glass you'll see a thin plastic frame. Insert a plectrum or prying tool. As the top and the bottom are very firmly glued, you'd best start in the middle of the side opposite the connector you loosened in the previous step. You have to use some force here and you'll probably see your screen splintering further.
      Ask FixBot
      • As soon as you have an opening, insert a credit card to keep it open. Work your way around; avoid inserting tools to try wrench it open. Break the screen where necessary but be careful to not damage or deform the plastic cover since that is the part you are going to re-use. Pull the connector through the slit.
      Ask FixBot
      • Cleaning up. Gently use a precision screwdrive to remove all glass parts, then scrape of all rubbery black glue. WARNING: do not touch the circle of metal contacts around the loudspeaker top-middle; they are lying a bit lower than the surrounding plastic. The sides contain rubbery glue as well.
      Ask FixBot
      • Apply a thin layer of glue on top and bottom and on the sides where the glass will go. Evidently 'thin' is the operative word here - you don't want glue sprouting out when you're fitting in the screen. I used a prying tool for the sides; top and bottom are less critical but you should of course stay well clear of the loudspeaker.
      Ask FixBot
      • Fit in the new screen, taking care the connector goes through the slit. Gently push where glue was applied.
      Ask FixBot
      • Turn the module over and connect the ribbon connector. A photograph of the right position may help here. If the connector is held in the right place, only small pressure down is required.
      Ask FixBot
      • Refit the protective metal around the connector. You now have a 'display module' in the sense described in the other manual, so just work your way back through the steps to get your phone fully reassembled.
      Ask FixBot
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
Hans Mabelis
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 86
All Time: 101
