RIDGID R84015 X2 Speed Switch Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
85
All Time:
4,296
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
The speed (1-2) Switch is either stuck or won't change speed of rotation.
Tools
    1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
      • Remove the backplate.
      • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
      Ask FixBot
    2. RIDGID R84015 X2 Speed Switch Replacement: step 2, image 1 of 1
      • Remove the drill handle.
      • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
      Ask FixBot
    3. RIDGID R84015 X2 Speed Switch Replacement: step 3, image 1 of 2 RIDGID R84015 X2 Speed Switch Replacement: step 3, image 2 of 2
      • Remove the gear casing from the body.
      • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
      Ask FixBot
    1. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: step 4, image 1 of 1
      • Locate small metal bar above plastic part of drill.
      • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
      Ask FixBot
    2. RIDGID R84015 X2 Speed Switch Replacement: step 5, image 1 of 2 RIDGID R84015 X2 Speed Switch Replacement: step 5, image 2 of 2
      • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
      • Make sure the small tabs on the underside of the switch that move the bar are intact.
      • Replace switch as needed.
      Ask FixBot
2 other people completed this guide.
Evan Long
274 Reputation
4 Guides authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 85
All Time: 4,296
