RIDGID R84015 X2 Planetary Gear Replacement Guide
Views: 7.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
37
Past 30 Days:
152
All Time:
7,376
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow these steps to disassemble the drill and replace the planetary gear for the RIDGID R84015 X2 power drill.
Tools
    1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
      • Remove the backplate.
      • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
      Ask FixBot
    2. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 2, image 1 of 1
      • Remove the drill handle.
      • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
      Ask FixBot
    3. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 3, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 3, image 2 of 2
      • Remove the gear casing from the body.
      • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
      Ask FixBot
    1. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: step 4, image 1 of 1
      • Prepare to remove the gear chamber.
      • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
      Ask FixBot
    2. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 5, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 5, image 2 of 2
      • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
      • NOTE: Handle the gear chamber with caution as the gears are now loose.
      Ask FixBot
    3. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 6, image 1 of 1
      • Remove the plastic gear chamber.
      • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
      Ask FixBot
    4. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 7, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 7, image 2 of 2
      • Remove each component from the gear assembly. Replace components as needed.
      • Reassemble the drill following the gear replacement instructions in reverse order.
      Ask FixBot
Finish Line
4 other people completed this guide.
Evan Long
274 Reputation
4 Guides authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
60 Guides authored
1 Guide Comment
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Reply Share
Past 24 Hours: 11
Past 7 Days: 37
Past 30 Days: 152
All Time: 7,376
