Up to 20% off select tools
PowerLead Puto PLD003 Zoom Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
89
All Time:
754
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the side panel from the camera, how to remove the back panel, and how to replace the zoom button.
    1. PowerLead Puto PLD003 Zoom Button Replacement, Side Panel: step 1, image 1 of 1
      • Slide the battery eject button open to release the battery door.
      Ask FixBot
    2. PowerLead Puto PLD003 Zoom Button Replacement: step 2, image 1 of 1
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      Ask FixBot
    3. PowerLead Puto PLD003 Zoom Button Replacement: step 3, image 1 of 1
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      Ask FixBot
    4. PowerLead Puto PLD003 Zoom Button Replacement: step 4, image 1 of 1
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      Ask FixBot
    1. PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: step 5, image 1 of 2 PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: step 5, image 2 of 2
      • Remove the 4 mm Phillips #1 screws holding the weight.
      • Remove the weight.
      Ask FixBot
    2. PowerLead Puto PLD003 Zoom Button Replacement: step 6, image 1 of 1
      • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
      Ask FixBot
    3. PowerLead Puto PLD003 Zoom Button Replacement: step 7, image 1 of 1
      • Apply pressure to the back panel, pulling away from the camera to remove it.
      Ask FixBot
    4. PowerLead Puto PLD003 Zoom Button Replacement: step 8, image 1 of 2 PowerLead Puto PLD003 Zoom Button Replacement: step 8, image 2 of 2
      • Remove the final 4 mm Phillips #1 screw holding the screen in place.
      • This screw is very small and hard to see.
      Ask FixBot
    5. PowerLead Puto PLD003 Zoom Button Replacement: step 9, image 1 of 1
      • Carefully apply pressure away from the camera to the screen to detach it from the body.
      • The white cord should still be connected to the body.
      • OPTIONAL: Remove the screen to make accessing the zoom button easier.
      Ask FixBot
    6. PowerLead Puto PLD003 Zoom Button Replacement: step 10, image 1 of 1
      • Remove the three 4 mm Phillips #1 screws holding the top panel in place.
      Ask FixBot
    7. PowerLead Puto PLD003 Zoom Button Replacement: step 11, image 1 of 2 PowerLead Puto PLD003 Zoom Button Replacement: step 11, image 2 of 2
      • Push upward on the top panel to remove it from the body of the camera.
      Ask FixBot
    8. PowerLead Puto PLD003 Zoom Button Replacement: step 12, image 1 of 2 PowerLead Puto PLD003 Zoom Button Replacement: step 12, image 2 of 2
      • Remove the two 4 mm Phillips #1 screws holding the circuit board in place.
      • Do not remove the silver screws.
      Ask FixBot
    9. PowerLead Puto PLD003 Zoom Button Replacement: step 13, image 1 of 1
      • Lift the circuit board out of the plastic casing.
      • Gently pull on the zoom button to remove it from the circuit board.
      Ask FixBot
Author
with
Justin Tew
791 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 89
All Time: 754
