Up to 20% off select tools
PowerLead Puto PLD003 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
89
All Time:
862
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the side panel from the camera, how to remove the back panel, and how to replace the LCD screen.
    1. PowerLead Puto PLD003 Screen Replacement, Side Panel: step 1, image 1 of 1
      • Slide the battery eject button open to release the battery door.
      Ask FixBot
    2. PowerLead Puto PLD003 Screen Replacement: step 2, image 1 of 1
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      Ask FixBot
    3. PowerLead Puto PLD003 Screen Replacement: step 3, image 1 of 1
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      Ask FixBot
    4. PowerLead Puto PLD003 Screen Replacement: step 4, image 1 of 1
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      Ask FixBot
    1. PowerLead Puto PLD003 Screen Replacement, Screen: step 5, image 1 of 2 PowerLead Puto PLD003 Screen Replacement, Screen: step 5, image 2 of 2
      • Remove the three 4 mm Phillips #1 screws holding the weight.
      • Remove the weight.
      Ask FixBot
    2. PowerLead Puto PLD003 Screen Replacement: step 6, image 1 of 1
      • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
      Ask FixBot
    3. PowerLead Puto PLD003 Screen Replacement: step 7, image 1 of 1
      • Remove the back panel away from the camera by applying pressure to it.
      Ask FixBot
    4. PowerLead Puto PLD003 Screen Replacement: step 8, image 1 of 2 PowerLead Puto PLD003 Screen Replacement: step 8, image 2 of 2
      • Set aside back panel for now.
      • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
      Ask FixBot
    5. PowerLead Puto PLD003 Screen Replacement: step 9, image 1 of 1
      • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
      • The white cord should still be connected to the body.
      Ask FixBot
    6. PowerLead Puto PLD003 Screen Replacement: step 10, image 1 of 2 PowerLead Puto PLD003 Screen Replacement: step 10, image 2 of 2
      • Lift the black clip upward.
      • With the clip up, pull the white cord to the left. This will detach the screen from the body.
      Ask FixBot
Author
with
Justin Tew
791 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 89
All Time: 862
