Polar V800 Battery Replacement
Views: 23K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
127
All Time:
23,239
Comments: 62
7 comments on steps, 55 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show users how to replace the battery in the Polar V800. If the battery appears at the end of its life cycle or has become swollen, then the battery may need to be replaced to keep your Polar V800 sport watch operating as it should.
Tools
    1. Polar V800 Battery Replacement, Waterproofing Seal: step 1, image 1 of 2 Polar V800 Battery Replacement, Waterproofing Seal: step 1, image 2 of 2
      • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
      • Ensure your Polar V800 sports watch is powered off before continuing.
      • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
      Ask FixBot
    2. Polar V800 Battery Replacement: step 2, image 1 of 3 Polar V800 Battery Replacement: step 2, image 2 of 3 Polar V800 Battery Replacement: step 2, image 3 of 3
      • Gently separate the watch housing from the back panel.
      • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
      Ask FixBot
    3. Polar V800 Battery Replacement: step 3, image 1 of 2 Polar V800 Battery Replacement: step 3, image 2 of 2
      • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
      • Remove the waterproofing seal.
      • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
      Ask FixBot
    1. Polar V800 Battery Replacement, Motherboard: step 4, image 1 of 3 Polar V800 Battery Replacement, Motherboard: step 4, image 2 of 3 Polar V800 Battery Replacement, Motherboard: step 4, image 3 of 3
      • Though not necessary, following the Polar V800 Display Replacement first may make the motherboard easier to remove.
      • Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
      Ask FixBot
    2. Polar V800 Battery Replacement: step 5, image 1 of 1
      • Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
      • A red wire and a black wire should run between the motherboard and the battery.
      Ask FixBot
    3. Polar V800 Battery Replacement: step 6, image 1 of 1
      • The battery is glued down to the back of the watch. It may take some force to detach the battery at the glue joint.
      • Use a spudger to pry the battery from the back of the watch.
      • If your battery is swollen, be very careful in removing the battery. If the packaging is ruptured, the battery will be unsafe to handle with bare hands. The contents of the battery are hazardous.
      Ask FixBot
    4. Polar V800 Battery Replacement: step 7, image 1 of 1
      • Gently pull the wires from their solder joints to disconnect them from the body of the watch.
      • If the wires do not come off easily, you may need to desolder the connections. Visit How To Solder and Desolder Connections for more help on soldering.
      • To reconnect the wires to their solder joints, they must be soldered on. See the guide linked above for more guidance.
      Ask FixBot
    1. Polar V800 Battery Replacement, Battery: step 8, image 1 of 2 Polar V800 Battery Replacement, Battery: step 8, image 2 of 2
      • To remove the battery, desolder the black and red wires connecting the battery to the motherboard and remove the battery. See this guide on How To Solder and Desolder Connections for additional help.
      Ask FixBot
16 other people completed this guide.
Jarod Lyles
835 Reputation
5 Guides authored
Cal Poly, Team S17-G6, Livingston Spring 2018 Member of Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Members
72 Guides authored
55 Guide Comments
@jarodlyles Where can I buy those 7.4 mm long screws? I tried to open my V800 and I think I might have ruined the groves on the screw head. Now, the screw driver just rotates and does not screw in. I am thinking of buying new screws to replace the old ones. Please let me know.
kamcat - Reply Share
I found so many 3.7 V 350 mAH LiPo batteries with a bit different dimensions. I wan’t to buy the right, before try to change it.
Can you please specify the dimensions of the battery? Or, if possible, a direct link to order one (eBay, Amazon, some shop witch delivery to germany)?
Thanks
KlausiHH - Reply Share
I can't find a replacement battery for V800 anywhere.
Hans Ekko - Reply Share
Same problem here: where should I buy the replacement battery? Nothing, really nothing found online… :(
Olaf Gottschalk - Reply Share
Did you really replaced the battery with a new? Then, why don’t you can answer where to buy a new? Or do you just dismounted it, to show how it can work?
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 127
All Time: 23,239
