Polar V800 Watch Band Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
79
All Time:
8,549
Comments: 8
8 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show users how to remove and replace the watch band on the Polar V800 sports watch. If the watch band needs to be swapped for a different sized watch band or the watch band is broken or wearing out, this is the perfect guide to putting your watch back where it belongs (on your wrist!).
Tools
    1. Polar V800 Watch Band Replacement, Watch Band: step 1, image 1 of 3 Polar V800 Watch Band Replacement, Watch Band: step 1, image 2 of 3 Polar V800 Watch Band Replacement, Watch Band: step 1, image 3 of 3
      • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
      • Completely pull out the pins.
      • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
      • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
      Ask FixBot
    2. Polar V800 Watch Band Replacement: step 2, image 1 of 3 Polar V800 Watch Band Replacement: step 2, image 2 of 3 Polar V800 Watch Band Replacement: step 2, image 3 of 3
      • To remove the watch band, pull each end of the watch band away from the watch frame.
      Ask FixBot
Jarod Lyles
835 Reputation
5 Guides authored
Cal Poly, Team S17-G6, Livingston Spring 2018 Member of Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Members
72 Guides authored
8 Guide Comments
There is no way for me to remove the clips, they are stuck and don’t move, any ideas on how to loosen them?
Gustavo Fette - Reply Share
I have the same issue. Any idea?
smichaud777 - Reply Share
Same issue here, they wont budge. You guys above found any solution?
Kris - Reply Share
No, I guess I won’t Be buying Polar stuff no more… can’t believe it…
The Pins move out! Like described above, there is one side with a larger head of the pin. This is the side where the pin comes out. The smaller side is where you push. Due to water and sweat, there is some kind off corrosion or buildup around the pin.This is why it does not come out easy. Important is to use right size of the tool. Lubrication with WD40 silicone oil helps.
Michael_B - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 79
All Time: 8,549
