This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓If the barometer/altimeter starts to behave erratically, you can start by following the basic troubleshooting steps recommended by Polar: altimeter calibration, watch restart, watch cleaning, cleaning the sensor entry (https://www.youtube.com/watch?v=pZslSi8h...), contacting Polar technical support (it is possible they may offer you a 30% discount on a new watch...)
If these steps do not solve the problem and in particular if:
- the watch freezes (the only way to unblock it is a reset) when you start a calibration
- no altitude information is displayed
then the altimeter may be broken.
WARNING, this is not an easy repair, you may make the watch unusable by attempting it.
Tools
Spudger4.9
Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
Using a small flathead screwdriver or pliers, remove the red seal around the barometric sensor.
The sensor is strongly glued and welded on the mother board. Beware of the micro components positioned nearby, avoid taking support on them when removing the seal.
Unsolder or cut short the black/red wires soldered on the casing.
With a 350°C soldering iron and a desoldering wick remove as much solder as possible. Then try to remove the component with angled pliers
It is likely that the component is glued to the board. In this case, the only solution that I've found was to remove the component by cutting it piece by piece with mini flush cutters.
The target is to get a surface where to put the new component as clean as possible, while keeping the soldering pads and without destroying nearby components. That is the most complex operation.
Put a VERY SMALL drop of glue (no superglue, use a glue that solidifies slower like epoxy so that you can correct misplacement of the component if it does not align with the solder pads) in the component placement area and put it in there (take care to place the component so that the blue dot is at the right position!)
Solder the 4 contacts with a thin tip soldering iron. The use of flux will make the operation easier.
Follow instruction in reverse order to assemble the device. Do not forget to resolder the black/red wires to the casing.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
