Pentax Optio WG-2 LCD Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
98
All Time:
1,650
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the LCD viewing screen on the back of the Pentax Optio WG-2.
Tools
    1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
      Pentax Optio WG-2 LCD Screen Replacement, Back Case: step 1, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement, Back Case: step 1, image 2 of 2
      • Remove all four 1 mm JIS #00 screws from the back of the camera.
      Ask FixBot
    2. Pentax Optio WG-2 LCD Screen Replacement: step 2, image 1 of 1
      • Use your finger to peel the grip off the top of the camera.
      • For best results, start from the right side of the camera, opposite the buttons.
      • Once the grip is removed, you will most likely lose the water-tight seal.
      Ask FixBot
    3. Pentax Optio WG-2 LCD Screen Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to remove the two buttons from the top of the camera.
      • The buttons may fall out while removing the grip.
      Ask FixBot
    4. Pentax Optio WG-2 LCD Screen Replacement: step 4, image 1 of 3 Pentax Optio WG-2 LCD Screen Replacement: step 4, image 2 of 3 Pentax Optio WG-2 LCD Screen Replacement: step 4, image 3 of 3
      • Remove the three 1 mm JIS #000 screws from the top.
      • Remove the 1 mm JIS #000 screw from the bottom.
      Ask FixBot
    5. Pentax Optio WG-2 LCD Screen Replacement: step 5, image 1 of 1
      • Carefully separate the back and the front of the camera.
      • There are three ribbon cables connecting the two boards. Be careful not to tear them.
      Ask FixBot
    6. Pentax Optio WG-2 LCD Screen Replacement: step 6, image 1 of 1
      • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
      • Carefully pull the ribbon cables out of their sockets.
      Ask FixBot
    1. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
      Buy
      • Carefully remove the clear tape covering the screws and the ribbon cable.
      • Be careful not to tear the ribbon cable when removing the tape.
      • We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
      Ask FixBot
    2. Pentax Optio WG-2 LCD Screen Replacement: step 8, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement: step 8, image 2 of 2
      • Once the screen is removed you should have two pieces as seen in the picture.
      • The screen is the silver rectangle in the top of the picture or the component seen in picture two.
      Ask FixBot
2 other people completed this guide.
Matthew Bessette
658 Reputation
6 Guides authored
2 Guide Comments
Dónde puedo comprar el Display?
Where I can buy the dispaly?
Sebastian Mesa - Reply Share
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
walchkorn - Reply Share
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 98
All Time: 1,650
