Pentax Optio WG-2 Back Case Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
23
All Time:
351
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to replace the rear case of the Pentax Optio WG-2.
Tools
    1. Pentax Optio WG-2 Back Case Replacement, Back Case: step 1, image 1 of 2 Pentax Optio WG-2 Back Case Replacement, Back Case: step 1, image 2 of 2
      • Remove all four 1 mm JIS #00 screws from the back of the camera.
      Ask FixBot
    2. Pentax Optio WG-2 Back Case Replacement: step 2, image 1 of 1
      • Use your finger to peel the grip off the top of the camera.
      • For best results, start from the right side of the camera, opposite the buttons.
      • Once the grip is removed, you will most likely lose the water-tight seal.
      Ask FixBot
    3. Pentax Optio WG-2 Back Case Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to remove the two buttons from the top of the camera.
      • The buttons may fall out while removing the grip.
      Ask FixBot
    4. Pentax Optio WG-2 Back Case Replacement: step 4, image 1 of 3 Pentax Optio WG-2 Back Case Replacement: step 4, image 2 of 3 Pentax Optio WG-2 Back Case Replacement: step 4, image 3 of 3
      • Remove the three 1 mm JIS #000 screws from the top.
      • Remove the 1 mm JIS #000 screw from the bottom.
      Ask FixBot
    5. Pentax Optio WG-2 Back Case Replacement: step 5, image 1 of 1
      • Carefully separate the back and the front of the camera.
      • There are three ribbon cables connecting the two boards. Be careful not to tear them.
      Ask FixBot
    6. Pentax Optio WG-2 Back Case Replacement: step 6, image 1 of 1
      • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
      • Carefully pull the ribbon cables out of their sockets.
      Ask FixBot
Matthew Bessette
658 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 351
