Patching a Bicycle Tire Inner Tube
    1. Patching a Bicycle Tire Inner Tube, Inner Tube: step 1, image 1 of 1
      • Press the valve core while applying pressure to the tire to deflate the tire.
      Ask FixBot
    2. Patching a Bicycle Tire Inner Tube: step 2, image 1 of 2 Patching a Bicycle Tire Inner Tube: step 2, image 2 of 2
      • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
      • Slide the lever around the circumference of the wheel to completely remove the tire.
      • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
      Ask FixBot
    3. Patching a Bicycle Tire Inner Tube: step 3, image 1 of 1
      • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
      Ask FixBot
    1. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: step 4, image 1 of 2 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: step 4, image 2 of 2
      • Locate the leak by first over inflating the tire.
      • Place the tire under water and look for bubbles to find the leak.
      Ask FixBot
    2. Patching a Bicycle Tire Inner Tube: step 5, image 1 of 1
      • Mark the hole with a marker, and completely deflate the tire.
      Ask FixBot
    3. Patching a Bicycle Tire Inner Tube: step 6, image 1 of 1
      • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
      Ask FixBot
    4. Patching a Bicycle Tire Inner Tube: step 7, image 1 of 1
      • Clean the area near the hole with soap and water, then dry it thoroughly.
      • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
      Ask FixBot
    5. Patching a Bicycle Tire Inner Tube: step 8, image 1 of 1
      • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
      Ask FixBot
    6. Patching a Bicycle Tire Inner Tube: step 9, image 1 of 1
      • Apply the patch to the area.
      Ask FixBot
    7. Patching a Bicycle Tire Inner Tube: step 10, image 1 of 1
      • Apply pressure to the patch until the rubber cement is dry.
      Ask FixBot
To reassemble your bike, follow these directions from step 6
2 other people completed this guide.
Brett Hartt
132,360 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 58
All Time: 2,453
