Up to 20% off select tools
Nintendo Switch Pro Controller Rumble Modules Replacement
Views: 15K
View statistics:
Past 24 Hours:
13
Past 7 Days:
60
Past 30 Days:
369
All Time:
15,306
Comments: 20
18 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
This guide is used for the replacement of the Rumble Modules on your Nintendo Switch Pro Controller. Take precaution when completing this guide because it involves the removal of a lithium-ion battery. If the battery is swollen, check out this resource on how to dispose of a swollen battery. To complete this guide correctly you must complete steps eight and nine with caution so as to not damage the white ribbon. In addition, you must be able to solder, so if you do not know how to solder, check out this resource on how to solder. Be careful when removing the plastic pieces and the internal circuit board of the controller so as to not damage the components.
    1. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: step 1, image 1 of 1
      • Flip the controller over so the model stickers face the ceiling.
      • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
      Ask FixBot
    2. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: step 2, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: step 2, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the handle covers: step 2, image 3 of 3
      • Carefully remove the handle covers by pulling them away from the main body.
      Ask FixBot
    3. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: step 3, image 1 of 1
      • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
      Ask FixBot
    4. Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: step 4, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: step 4, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Unclip the plastic cover: step 4, image 3 of 3
      • Carefully pry away the clear plastic cover using your fingernail.
      Ask FixBot
    5. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the clear plastic cover: step 5, image 1 of 1
      • Remove the clear plastic cover.
      Ask FixBot
    6. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: step 6, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: step 6, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the battery: step 6, image 3 of 3
      • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
      • Only a small amount of force is needed.
      Ask FixBot
    1. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: step 7, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: step 7, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the screws: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
      • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
      • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
      Ask FixBot
    2. Nintendo Switch Pro Controller Rumble Modules Replacement: step 8, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement: step 8, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement: step 8, image 3 of 3
      • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
      • Delicately take off the plastic cover from the controller.
      • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
      Ask FixBot
    3. Nintendo Switch Pro Controller Rumble Modules Replacement, Open the flap: step 9, image 1 of 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Open the flap: step 9, image 2 of 2
      • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
      Ask FixBot
    4. Nintendo Switch Pro Controller Rumble Modules Replacement, Disconnect the interconnect cable: step 10, image 1 of 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Disconnect the interconnect cable: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
      Ask FixBot
    5. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the front case: step 11, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: step 12, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: step 12, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the joystick caps: step 12, image 3 of 3
      • With light force pull the two joystick caps off of the controller.
      Ask FixBot
    1. Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: step 13, image 1 of 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: step 13, image 2 of 2
      • Insert the tip of a spudger from the back into the hole on the right controller handle.
      • Push the spudger through the hole to loosen the adhesive which is holding rumble modules in their places.
      Ask FixBot
    2. Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: step 14, image 1 of 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Loosen the adhesive: step 14, image 2 of 2
      • Insert the tip of a spudger from the back into the hole on the left controller handle.
      Ask FixBot
    3. Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the modules: step 15, image 1 of 2 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the modules: step 15, image 2 of 2
      Buy
      • Use a pair tweezers to lift the modules out of their places.
      Ask FixBot
    4. Nintendo Switch Pro Controller Rumble Modules Replacement, Unscrew the motherboard: step 16, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four 5 mm-long screws securing the motherboard.
      Ask FixBot
    5. Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: step 17, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: step 17, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Remove the LED light: step 17, image 3 of 3
      • Use your thumb or a pair of tweezers to to take off the white LED light housing.
      Ask FixBot
    6. Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: step 18, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: step 18, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Lift the motherboard: step 18, image 3 of 3
      • Lift the motherboard carefully as to not damage the wires and flip it to reveal the backside.
      Ask FixBot
    7. Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: step 19, image 1 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: step 19, image 2 of 3 Nintendo Switch Pro Controller Rumble Modules Replacement, Desolder the rumble modules: step 19, image 3 of 3
      • Desolder the rumble motor solder points on either side of the motherboard.
      • Remove the rumble modules.
      • Refer to the following solder guide if necessary: How to Solder
      • Solder the new rumble modules into the same pins.
      Ask FixBot
2 Guide Comments
Is the controller operational if I just leave the rumble module de-soldered?
amp - Reply Share
It is! Somehow the one motor on the right hand side of mine started heating up and smoking, so I took it out. Left one is still fine, so I still get some rumble, and controller works as normal.
OtherScott - Reply Share
Past 24 Hours: 13
Past 7 Days: 60
Past 30 Days: 369
All Time: 15,306
