Up to 20% off select tools
Nintendo Switch Pro Controller Joystick Caps Replacement
Views: 37K
View statistics:
Past 24 Hours:
17
Past 7 Days:
143
Past 30 Days:
743
All Time:
36,566
Comments: 20
17 comments on steps, 3 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
After using the Nintendo Switch Pro Controller (Model HAC-001), it is common that the joystick cap becomes cracked or broken.  Though the caps are not integral to the functionality of the controller, the caps provide comfort and ease of use of the joysticks.  This guide helps with only the replacement of the joystick caps, not the joystick itself.
    1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: step 1, image 1 of 1
      • Flip the controller over so the model stickers face the ceiling.
      • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
      Ask FixBot
    2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: step 2, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: step 2, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: step 2, image 3 of 3
      • Carefully remove the handle covers by pulling them away from the main body.
      Ask FixBot
    3. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: step 3, image 1 of 1
      • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
      Ask FixBot
    4. Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: step 4, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: step 4, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: step 4, image 3 of 3
      • Carefully pry away the clear plastic cover using your fingernail.
      Ask FixBot
    5. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the clear plastic cover: step 5, image 1 of 1
      • Remove the clear plastic cover.
      Ask FixBot
    6. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: step 6, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: step 6, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: step 6, image 3 of 3
      • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
      • Only a small amount of force is needed.
      Ask FixBot
    1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: step 7, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: step 7, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
      • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
      • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
      Ask FixBot
    2. Nintendo Switch Pro Controller Joystick Caps Replacement: step 8, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement: step 8, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement: step 8, image 3 of 3
      • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
      • Delicately take off the plastic cover from the controller.
      • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
      Ask FixBot
    3. Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: step 9, image 1 of 2 Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: step 9, image 2 of 2
      • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
      Ask FixBot
    4. Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: step 10, image 1 of 2 Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
      Ask FixBot
    5. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the front case: step 11, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: step 12, image 1 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: step 12, image 2 of 3 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: step 12, image 3 of 3
      • With light force pull the two joystick caps off of the controller.
      Ask FixBot
34 other people completed this guide.
Author
with
Christian Rudnick
623 Reputation
1 Guide authored
Cal Poly, Team S11-G2, Regan Fall 2019 Member of Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Members
72 Guides authored
3 Guide Comments
Where can I get the replacement caps?
Locke Valentine - Reply Share
do you know where to find a replacement cap? If so can you give me link, thanks!
Jesus Acosta - Reply Share
You really don't need to disconnect the ZIF to replace the caps. It might make things a tiny bit easier, but is best not to mess with it AT ALL if you're only replacing the caps. As messing it up, or not connecting it properly when you're putting it back together can lead to ALL your face buttons and D-pad not working.
master2873 - Reply Share
Past 24 Hours: 17
Past 7 Days: 143
Past 30 Days: 743
All Time: 36,566
