Up to 20% off select tools
Nintendo Switch Pro Controller Front Button Replacement
Views: 20K
View statistics:
Past 24 Hours:
7
Past 7 Days:
48
Past 30 Days:
287
All Time:
20,108
Comments: 23
19 comments on steps, 4 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The front buttons on a Nintendo switch pro controller are supposed to be free flowing and have lightning fast response time. If your controller is not performing at the highest level it can then that means you will keep losing games. The controller has to be the best it can possibly be so that you can play up to your ultimate potential. If your front buttons are sticky, unresponsive, or will not press down all the way, use this guide to remove and replace your buttons. This guide requires a Phillips #00 screwdriver for screw removal.
    1. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 1, image 1 of 1
      • Flip the controller over so the model stickers face the ceiling.
      • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
      Ask FixBot
    2. Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: step 2, image 1 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: step 2, image 2 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: step 2, image 3 of 3
      • Carefully remove the handle covers by pulling them away from the main body.
      Ask FixBot
    3. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 3, image 1 of 1
      • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
      Ask FixBot
    4. Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: step 4, image 1 of 3 Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: step 4, image 2 of 3 Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: step 4, image 3 of 3
      • Carefully pry away the clear plastic cover using your fingernail.
      Ask FixBot
    5. Nintendo Switch Pro Controller Front Button Replacement, Remove the clear plastic cover: step 5, image 1 of 1
      • Remove the clear plastic cover.
      Ask FixBot
    6. Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: step 6, image 1 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: step 6, image 2 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: step 6, image 3 of 3
      • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
      • Only a small amount of force is needed.
      Ask FixBot
    1. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 7, image 1 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 7, image 2 of 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
      • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
      • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
      Ask FixBot
    2. Nintendo Switch Pro Controller Front Button Replacement: step 8, image 1 of 3 Nintendo Switch Pro Controller Front Button Replacement: step 8, image 2 of 3 Nintendo Switch Pro Controller Front Button Replacement: step 8, image 3 of 3
      • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
      • Delicately take off the plastic cover from the controller.
      • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
      Ask FixBot
    3. Nintendo Switch Pro Controller Front Button Replacement, Open the flap: step 9, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement, Open the flap: step 9, image 2 of 2
      • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
      Ask FixBot
    4. Nintendo Switch Pro Controller Front Button Replacement, Disconnect the interconnect cable: step 10, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement, Disconnect the interconnect cable: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
      Ask FixBot
    5. Nintendo Switch Pro Controller Front Button Replacement, Remove the front case: step 11, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: step 12, image 1 of 1
      • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
      Ask FixBot
    2. Nintendo Switch Pro Controller Front Button Replacement, Open the ZIF connector: step 13, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement, Open the ZIF connector: step 13, image 2 of 2
      • Use a spudger to flip up the locking tab on the ZIF connector.
      Ask FixBot
    3. Nintendo Switch Pro Controller Front Button Replacement: step 14, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement: step 14, image 2 of 2
      • Remove the black ribbon cable from its connector.
      • Only a small amount of force should be needed to remove the ribbon cable.
      Ask FixBot
    4. Nintendo Switch Pro Controller Front Button Replacement: step 15, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement: step 15, image 2 of 2
      • Remove the trigger buttons from the plastic cover.
      Ask FixBot
    1. Nintendo Switch Pro Controller Front Button Replacement, Unscrew front button board: step 16, image 1 of 1
      • Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
      • There may be an additional screw. If so, remove it now.
      Ask FixBot
    2. Nintendo Switch Pro Controller Front Button Replacement, Remove the board: step 17, image 1 of 2 Nintendo Switch Pro Controller Front Button Replacement, Remove the board: step 17, image 2 of 2
      • Remove the front button board.
      Ask FixBot
9 other people completed this guide.
Author
with
Daniel Tagalog
2,219 Reputation
3 Guides authored
Cal Poly, Team S11-G2, Regan Fall 2019 Member of Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Members
72 Guides authored
4 Guide Comments
Hey Daniel! Thank you very much for this tutorial.
May I ask you, do you know the part code of this specific board or where I can find it online?? My pro controller d-pad came malfunctioning from factory and I think I’ll challenge myself to try and buy a new one to replace it.
Tassio - Reply Share
I broke the locking tab on the ZIF connector what can I do?
Jonathan Martinez - Reply Share
I’ve been looking myself and can’t find any replacement button board to buy - just asking again if anyone knows how to find or where to buy one?
Brandon Green - Reply Share
if anyone else is reading this article... I easily found a nice set of replacement buttons that fit well on zedlabz. they're made in china and they are good quality rigid plastic with pleasant texturizing so they are easy to grip and press. happy fixing!
George Harrison Fricklas - Reply Share
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 287
All Time: 20,108
