Nintendo 3DS Wi-Fi Antenna Replacement
  1. Nintendo 3DS Wi-Fi Antenna Replacement, Loosen the rear screws: step 1, image 1 of 1
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    Ask FixBot
  2. Nintendo 3DS Wi-Fi Antenna Replacement, Remove the rear cover: step 2, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Remove the rear cover: step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    Ask FixBot
  3. Nintendo 3DS Wi-Fi Antenna Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
    Ask FixBot
  4. Nintendo 3DS Wi-Fi Antenna Replacement, Lower Case: step 4, image 1 of 1
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
    Ask FixBot
  5. Nintendo 3DS Wi-Fi Antenna Replacement: step 5, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 5, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 5, image 3 of 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    Ask FixBot
  6. Nintendo 3DS Wi-Fi Antenna Replacement, Circle Pad Joystick: step 6, image 1 of 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
    Ask FixBot
  7. Nintendo 3DS Wi-Fi Antenna Replacement: step 7, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 7, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 7, image 3 of 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
    Ask FixBot
  8. Nintendo 3DS Wi-Fi Antenna Replacement: step 8, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 8, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 8, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
    Ask FixBot
  9. Nintendo 3DS Wi-Fi Antenna Replacement: step 9, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 9, image 2 of 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
    Ask FixBot
  10. Nintendo 3DS Wi-Fi Antenna Replacement, SD Board: step 10, image 1 of 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
    Ask FixBot
  11. Nintendo 3DS Wi-Fi Antenna Replacement: step 11, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 11, image 2 of 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
    Ask FixBot
  12. Nintendo 3DS Wi-Fi Antenna Replacement: step 12, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 12, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 12, image 3 of 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    Ask FixBot
  13. Nintendo 3DS Wi-Fi Antenna Replacement, Pry the Wi-Fi card up: step 13, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Pry the Wi-Fi card up: step 13, image 2 of 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
    Ask FixBot
  14. Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: step 14, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: step 14, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement, Disconnect the Wi-Fi board: step 14, image 3 of 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
    Ask FixBot
  15. Nintendo 3DS Wi-Fi Antenna Replacement, Motherboard Assembly: step 15, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Motherboard Assembly: step 15, image 2 of 2
    Buy
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
    Ask FixBot
  16. Nintendo 3DS Wi-Fi Antenna Replacement: step 16, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 16, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 16, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
    Ask FixBot
  17. Nintendo 3DS Wi-Fi Antenna Replacement: step 17, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 17, image 2 of 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
    Ask FixBot
  18. Nintendo 3DS Wi-Fi Antenna Replacement: step 18, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 18, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 18, image 3 of 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
    Ask FixBot
  19. Nintendo 3DS Wi-Fi Antenna Replacement: step 19, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 19, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 19, image 3 of 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
    Ask FixBot
  20. Nintendo 3DS Wi-Fi Antenna Replacement: step 20, image 1 of 1
    • Remove the motherboard assembly from the rest of the device.
    Ask FixBot
  21. Nintendo 3DS Wi-Fi Antenna Replacement, Upper Display Front Panel: step 21, image 1 of 1
    Buy
    • Before continuing with disassembly, use a pair of tweezers to remove the clear plastic diffuser for the wireless notification LED. The small piece is likely to fall out on its own, and may be difficult to find if it lands on the floor.
    Ask FixBot
  22. Nintendo 3DS Wi-Fi Antenna Replacement: step 22, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 22, image 2 of 2
    • De-route the Wi-Fi antenna cable from the bottom of the upper case.
    • This step is not necessary if you are only replacing the front panel; however, the replacement of the upper screen, speakers, cameras, and Wi-Fi antenna require it.
    Ask FixBot
  23. Nintendo 3DS Wi-Fi Antenna Replacement: step 23, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 23, image 2 of 2
    • Heat the edges of the upper display front panel with a hair dryer or heat gun to soften the adhesive holding it to the display bezel.
    • Begin prying the edges of the front panel off with a plastic opening tool.
    • If it is difficult to pry the front panel off, reheat the area you are working on with the heat gun, and then return to prying. Applying excessive force could crack the front panel.
    Ask FixBot
  24. Nintendo 3DS Wi-Fi Antenna Replacement: step 24, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 24, image 2 of 2
    • Continue prying the remaining sides of the front panel by sliding the plastic opening tool down each edge.
    • Too little heat will result in excessive bending/breaking of the front panel, and too much will melt and destroy the LCD underneath. Take your time.
    Ask FixBot
  25. Nintendo 3DS Wi-Fi Antenna Replacement: step 25, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 25, image 2 of 2
    • With all of the sides free, lift the upper display front panel off the display bezel.
    Ask FixBot
  26. Nintendo 3DS Wi-Fi Antenna Replacement, Rear Display Bezel: step 26, image 1 of 1
    • Remove the six 3.6 mm Phillips screws securing the rear display bezel to the front display bezel.
    Ask FixBot
  27. Nintendo 3DS Wi-Fi Antenna Replacement: step 27, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 27, image 2 of 2
    • Flip the device over so that the rear display bezel is on top and the hinge is on the side opposite from you.
    • Lift the edge of the rear display bezel closest to you and rotate it towards the hinge.
    • Continue to lift the rear display bezel off the rest of the device until it is free.
    • There are clips toward the bottom of the rear display bezel holding it in place. Use enough force to disengage the clips, but be careful not to break them.
    Ask FixBot
  28. Nintendo 3DS Wi-Fi Antenna Replacement, Upper Display Assembly: step 28, image 1 of 1
    • Remove the 3D adjustment switch from the front display bezel.
    • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
    Ask FixBot
  29. Nintendo 3DS Wi-Fi Antenna Replacement: step 29, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 29, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 29, image 3 of 3
    • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
    • Push the hinge towards the center of the upper case. This will require a fair amount of force.
    • Before and after images of the hinge location when looking at the back of the upper display are shown.
    Ask FixBot
  30. Nintendo 3DS Wi-Fi Antenna Replacement: step 30, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 30, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 30, image 3 of 3
    • Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation.
    • Slowly pull the upper display assembly away from the upper case.
    • Make sure that the various ribbon cables are being fed through the slit in the upper case.
    • Separate the upper display assembly from the upper case.
    Ask FixBot
  31. Nintendo 3DS Wi-Fi Antenna Replacement, Speaker Assembly: step 31, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Speaker Assembly: step 31, image 2 of 2
    • Carefully feed the speaker assembly ribbon cable through the hole in the upper display bezel.
    • You must gently coil the ribbon cables (similar to an ice-cream cone) to allow them to fit - the cables are wider than the hole.
    Ask FixBot
  32. Nintendo 3DS Wi-Fi Antenna Replacement: step 32, image 1 of 1
    • Remove the 2.5 mm Phillips screw securing the right speaker board to the upper display bezel.
    Ask FixBot
  33. Nintendo 3DS Wi-Fi Antenna Replacement: step 33, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 33, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 33, image 3 of 3
    Buy
    • Use the flat end of a spudger or your fingernail to flip up the retaining flaps on the parallax barrier ribbon cable ZIF sockets.
    • Use a pair of metal tweezers to disconnect the two ribbon cables.
    Ask FixBot
  34. Nintendo 3DS Wi-Fi Antenna Replacement: step 34, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 34, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 34, image 3 of 3
    • Use the flat end of a spudger to pry the left and right speakers out of their places in the upper display bezel.
    • Pry the camera status LED out of the upper display bezel with the tip of a spudger.
    Ask FixBot
  35. Nintendo 3DS Wi-Fi Antenna Replacement: step 35, image 1 of 1
    • Remove the speaker assembly from the rest of the display assembly.
    Ask FixBot
  36. Nintendo 3DS Wi-Fi Antenna Replacement, Cameras: step 36, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Cameras: step 36, image 2 of 2
    • Gently roll the upper LCD ribbon cable and camera ribbon cable together and insert them into the hinge opening.
    Ask FixBot
  37. Nintendo 3DS Wi-Fi Antenna Replacement: step 37, image 1 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 37, image 2 of 3 Nintendo 3DS Wi-Fi Antenna Replacement: step 37, image 3 of 3
    Buy
    • Use a pair of metal tweezers to remove the black metal hinge ring from the upper display bezel.
    • Carefully pull the camera and upper LCD ribbon cables through their hole in the upper display bezel.
    Ask FixBot
  38. Nintendo 3DS Wi-Fi Antenna Replacement: step 38, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement: step 38, image 2 of 2
    • Peel the camera ribbon cable off the back of the upper LCD.
    • The ribbon cable is held to the back of the LCD housing by an adhesive, so pull on it gently to avoid tearing the ribbon cable.
    • Remove the camera ribbon cable assembly.
    Ask FixBot
  39. Nintendo 3DS Wi-Fi Antenna Replacement, Upper LCD: step 39, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Upper LCD: step 39, image 2 of 2
    • Use your thumbs to push the upper LCD from the front out of the upper display bezel.
    • Remove the upper LCD.
    Ask FixBot
  40. Nintendo 3DS Wi-Fi Antenna Replacement, Wi-Fi Antenna: step 40, image 1 of 2 Nintendo 3DS Wi-Fi Antenna Replacement, Wi-Fi Antenna: step 40, image 2 of 2
    • Pull the Wi-Fi antenna cable through its hole in the upper display bezel.
    • De-route the Wi-Fi antenna cable from the upper display bezel.
    Ask FixBot
  41. Nintendo 3DS Wi-Fi Antenna Replacement: step 41, image 1 of 1
    • Remove the Wi-Fi antenna from the upper display bezel.
    Ask FixBot
8 other people completed this guide.
David Hodson
156,310 Reputation
127 Guides authored
2 Guide Comments
this guide is idiotic, i followed it to the letter and all it did was make me realize that there is a much easier and much safer way of replacing the antenna; steps 1-29 (step 30 if you want to, not necessary though) are fine and right on the money, however pushing the ribbons through makes it way more difficult when you could just remove the antenna board, thred just the wire through leaving the ribbons unchanched, and put in the replacement board and thread the wire through, then reassemble the console. this method almost guarantees that the ribbons wont get scratch and you wont get frustrated.
Andrew Clayton - Reply Share
this is amazing i will going to follow all steps it seems very difficult before i read this but now this will really helpful and easier than i thought thank you!! Antenna Amplifier
Rachel Gelller - Reply Share
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 162
All Time: 22,679
