Up to 20% off select tools
Nintendo 3DS Upper Display Front Panel Replacement
Views: 50K
View statistics:
Past 24 Hours:
8
Past 7 Days:
77
Past 30 Days:
478
All Time:
49,824
Comments: 155
150 comments on steps, 5 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 2 hours
Difficulty: Difficult
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Tools
Introduction
Go to step 1 ↓
Remove the upper display front panel to replace it or to access the components inside the upper display assembly.
If you are just replacing the upper display panel, you can just heat it up, pry it off, and install the new one. There is no need to take apart everything at the bottom to replace the glass.
    1. Nintendo 3DS Upper Display Front Panel Replacement, Loosen the rear screws: step 1, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
      • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
      • The screws are held in place by locking washers, and will not come out of the back cover.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement, Remove the rear cover: step 2, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement, Remove the rear cover: step 2, image 2 of 2
      • Hold the device in one hand and turn it over.
      • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
      • Flip the 3DS over again so that the back cover is facing up.
      • Pull the back cover up and away from the rest of the device to remove it.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement, Battery: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch in the lower case above the battery.
      • Pry the battery up with the plastic opening tool.
      • Grab the top edge of the battery and lift it out of the lower case.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Lower Case: step 4, image 1 of 1
      • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
      • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
      • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
      • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement: step 5, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 5, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 5, image 3 of 3
      • Lift the bottom edge of the lower case off the rest of the 3DS.
      • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
      • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
      • Remove the lower case from the device.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Circle Pad Joystick: step 6, image 1 of 1
      • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement: step 7, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 7, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 7, image 3 of 3
      • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
      • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
      Ask FixBot
    3. Nintendo 3DS Upper Display Front Panel Replacement: step 8, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 8, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 8, image 3 of 3
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Lift the Circle Pad joystick off the motherboard.
      Ask FixBot
    4. Nintendo 3DS Upper Display Front Panel Replacement: step 9, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 9, image 2 of 2
      • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
      • Use a spudger or screwdriver to lift the pads up and remove them from the device.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, SD Board: step 10, image 1 of 1
      • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement: step 11, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 11, image 2 of 2
      • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
      Ask FixBot
    3. Nintendo 3DS Upper Display Front Panel Replacement: step 12, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 12, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 12, image 3 of 3
      • Insert the flat end of a spudger between the SD board and the motherboard.
      • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
      • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
      • Once completely freed, lift the SD board straight off the motherboard.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Pry the Wi-Fi card up: step 13, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement, Pry the Wi-Fi card up: step 13, image 2 of 2
      • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
      • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement, Disconnect the Wi-Fi board: step 14, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement, Disconnect the Wi-Fi board: step 14, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement, Disconnect the Wi-Fi board: step 14, image 3 of 3
      • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
      • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
      • Remove the Wi-Fi board from the device.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Motherboard Assembly: step 15, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement, Motherboard Assembly: step 15, image 2 of 2
      Buy
      • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
      • Pull the microphone straight up out of the upper case.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement: step 16, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 16, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 16, image 3 of 3
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
      • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
      Ask FixBot
    3. Nintendo 3DS Upper Display Front Panel Replacement: step 17, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 17, image 2 of 2
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
      • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
      Ask FixBot
    4. Nintendo 3DS Upper Display Front Panel Replacement: step 18, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 18, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 18, image 3 of 3
      • Remove seven Phillips screws securing the motherboard to the upper case:
      • Four 2.5 mm gold screws
      • Two 3.5 mm black screws
      • One 2.5 mm silver screw
      • When you remove this screw the volume slider can fall out.
      • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
      Ask FixBot
    5. Nintendo 3DS Upper Display Front Panel Replacement: step 19, image 1 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 19, image 2 of 3 Nintendo 3DS Upper Display Front Panel Replacement: step 19, image 3 of 3
      • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
      Ask FixBot
    6. Nintendo 3DS Upper Display Front Panel Replacement: step 20, image 1 of 1
      • Remove the motherboard assembly from the rest of the device.
      Ask FixBot
    1. Nintendo 3DS Upper Display Front Panel Replacement, Upper Display Front Panel: step 21, image 1 of 1
      Buy
      • Before continuing with disassembly, use a pair of tweezers to remove the clear plastic diffuser for the wireless notification LED. The small piece is likely to fall out on its own, and may be difficult to find if it lands on the floor.
      Ask FixBot
    2. Nintendo 3DS Upper Display Front Panel Replacement: step 22, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 22, image 2 of 2
      • De-route the Wi-Fi antenna cable from the bottom of the upper case.
      • This step is not necessary if you are only replacing the front panel; however, the replacement of the upper screen, speakers, cameras, and Wi-Fi antenna require it.
      Ask FixBot
    3. Nintendo 3DS Upper Display Front Panel Replacement: step 23, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 23, image 2 of 2
      • Heat the edges of the upper display front panel with a hair dryer or heat gun to soften the adhesive holding it to the display bezel.
      • Begin prying the edges of the front panel off with a plastic opening tool.
      • If it is difficult to pry the front panel off, reheat the area you are working on with the heat gun, and then return to prying. Applying excessive force could crack the front panel.
      Ask FixBot
    4. Nintendo 3DS Upper Display Front Panel Replacement: step 24, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 24, image 2 of 2
      • Continue prying the remaining sides of the front panel by sliding the plastic opening tool down each edge.
      • Too little heat will result in excessive bending/breaking of the front panel, and too much will melt and destroy the LCD underneath. Take your time.
      Ask FixBot
    5. Nintendo 3DS Upper Display Front Panel Replacement: step 25, image 1 of 2 Nintendo 3DS Upper Display Front Panel Replacement: step 25, image 2 of 2
      • With all of the sides free, lift the upper display front panel off the display bezel.
      Ask FixBot
13 other people completed this guide.
Author
with
David Hodson
157,488 Reputation
127 Guides authored
5 Guide Comments
Why remove the entire motherboard just for the upper screen? That seems completely unnecessary; just be careful with the heat gun.
Bryan Haley - Reply Share
Tehy remove the whole motherboard because if you pay attention ribbon cables attaching things from the top to the bottom, like the ribbon cable for the lcd that you cant remove from its socket without removing the other parts. They even have pictures on these guides… just focus a little more on paying attention and you will be alright
Johnny Blaze - Reply Share
Just to replace the front panel you don’t need to remove anything else, its just held down with adhesive, only reason to take apart is to replace the lcd itself which isn’t what this is about.
Sam Jordan - Reply Share
can i use a hair dryer
Sqwerks - Reply Share
組み立ての方が10倍難しい。
そちらも投稿してほしい
opa opa - Reply Share
Past 24 Hours: 8
Past 7 Days: 77
Past 30 Days: 478
All Time: 49,824
