Up to 20% off select tools
Nintendo 3DS Lower Case Replacement
Views: 23K
View statistics:
Past 24 Hours:
4
Past 7 Days:
61
Past 30 Days:
333
All Time:
23,385
Comments: 81
78 comments on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Remove your broken Nintendo 3DS lower case and replace it with a fresh one.
    1. Nintendo 3DS Lower Case Replacement, Loosen the rear screws: step 1, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
      • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
      • The screws are held in place by locking washers, and will not come out of the back cover.
      Ask FixBot
    2. Nintendo 3DS Lower Case Replacement, Remove the rear cover: step 2, image 1 of 2 Nintendo 3DS Lower Case Replacement, Remove the rear cover: step 2, image 2 of 2
      • Hold the device in one hand and turn it over.
      • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
      • Flip the 3DS over again so that the back cover is facing up.
      • Pull the back cover up and away from the rest of the device to remove it.
      Ask FixBot
    1. Nintendo 3DS Lower Case Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Lower Case Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Lower Case Replacement, Battery: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch in the lower case above the battery.
      • Pry the battery up with the plastic opening tool.
      • Grab the top edge of the battery and lift it out of the lower case.
      Ask FixBot
    1. Nintendo 3DS Lower Case Replacement, Lower Case: step 4, image 1 of 1
      • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
      • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
      • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
      • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
      Ask FixBot
    2. Nintendo 3DS Lower Case Replacement: step 5, image 1 of 3 Nintendo 3DS Lower Case Replacement: step 5, image 2 of 3 Nintendo 3DS Lower Case Replacement: step 5, image 3 of 3
      • Lift the bottom edge of the lower case off the rest of the 3DS.
      • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
      • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
      • Remove the lower case from the device.
      Ask FixBot
8 other people completed this guide.
Author
with
David Hodson
157,488 Reputation
127 Guides authored
3 Guide Comments
Is this guide for the original 3ds?
Glenn Racz - Reply Share
yessir it is
Electronik - Reply Share
havent tried it (was thinking of shell swapping to see how hard it is) but it seems kinda easy for moderate rating you just remove 14 screws sorry if im wrong
MyComputerMinecraft - Reply Share
Past 24 Hours: 4
Past 7 Days: 61
Past 30 Days: 333
All Time: 23,385
