Up to 20% off select tools
Nintendo 3DS Battery Replacement
Views: 153K
View statistics:
Past 24 Hours:
66
Past 7 Days:
487
Past 30 Days:
2,277
All Time:
153,351
Comments: 42
33 comments on steps, 9 guide comments.
Go to guide comments
Completed: 78
78 people have marked this guide "completed." Will you be next?
Favorites: 21
21 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Remove the battery in your Nintendo 3DS to replace it with a new one.
    1. Nintendo 3DS Battery Replacement, Loosen the rear screws: step 1, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
      • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
      • The screws are held in place by locking washers, and will not come out of the back cover.
      Ask FixBot
    2. Nintendo 3DS Battery Replacement, Remove the rear cover: step 2, image 1 of 2 Nintendo 3DS Battery Replacement, Remove the rear cover: step 2, image 2 of 2
      • Hold the device in one hand and turn it over.
      • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
      • Flip the 3DS over again so that the back cover is facing up.
      • Pull the back cover up and away from the rest of the device to remove it.
      Ask FixBot
    1. Nintendo 3DS Battery Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Battery Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Battery Replacement, Battery: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch in the lower case above the battery.
      • Pry the battery up with the plastic opening tool.
      • Grab the top edge of the battery and lift it out of the lower case.
      Ask FixBot
78 other people completed this guide.
Author
with
David Hodson
157,488 Reputation
127 Guides authored
9 Guide Comments
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Reply Share
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto - Reply Share
Easy as pie. Thanks for writing this guide!
3DRepairMan - Reply Share
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Reply Share
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Reply Share
Past 24 Hours: 66
Past 7 Days: 487
Past 30 Days: 2,277
All Time: 153,351
