Nikon D610 Flash Capacitor Replacement
    1. Nikon D610 Flash Capacitor Replacement, Battery: step 1, image 1 of 1
      • First, power off the device.
      Ask FixBot
    2. Nikon D610 Flash Capacitor Replacement: step 2, image 1 of 3 Nikon D610 Flash Capacitor Replacement: step 2, image 2 of 3 Nikon D610 Flash Capacitor Replacement: step 2, image 3 of 3
      • Set the camera so that it is sitting on its side.
      • Open the battery compartment door by sliding the release button towards the lens.
      • This will cause the door to "pop" open slightly
      Ask FixBot
    3. Nikon D610 Flash Capacitor Replacement: step 3, image 1 of 2 Nikon D610 Flash Capacitor Replacement: step 3, image 2 of 2
      • Now lift open the battery compartment door.
      • Push the yellow tab lock towards the center to release the battery.
      • This will cause the battery to jump up as there is a spring at the bottom.
      • Pull straight out, slowly on the battery.
      • Make sure you pay attention to which way the battery goes .
      Ask FixBot
    1. Nikon D610 Flash Capacitor Replacement, Outer Case: step 4, image 1 of 1
      • After removal of the battery. Pull the battery compartment door away from the lens.
      • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
      • Remove all the screws and the bottom face should pop off easily.
      Ask FixBot
    2. Nikon D610 Flash Capacitor Replacement: step 5, image 1 of 3 Nikon D610 Flash Capacitor Replacement: step 5, image 2 of 3 Nikon D610 Flash Capacitor Replacement: step 5, image 3 of 3
      • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
      • There are screws hidden in three separate spots.
      • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
      • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
      • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
      Ask FixBot
    3. Nikon D610 Flash Capacitor Replacement: step 6, image 1 of 2 Nikon D610 Flash Capacitor Replacement: step 6, image 2 of 2
      • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
      • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
      • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
      Ask FixBot
    4. Nikon D610 Flash Capacitor Replacement: step 7, image 1 of 2 Nikon D610 Flash Capacitor Replacement: step 7, image 2 of 2
      • The next piece to come off is the front plate and the red grip.
      • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
      • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
      • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
      Ask FixBot
    5. Nikon D610 Flash Capacitor Replacement: step 8, image 1 of 2 Nikon D610 Flash Capacitor Replacement: step 8, image 2 of 2
      • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
      • The screws come out and the cover comes straight off.
      • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
      • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
      • There are three wires that need to be disconnected.
      Ask FixBot
    1. Nikon D610 Flash Capacitor Replacement, Flash Capacitor: step 9, image 1 of 2 Nikon D610 Flash Capacitor Replacement, Flash Capacitor: step 9, image 2 of 2
      • The flash capacitor will be to the right of the lens on the front of the camera.
      • There is only one connection that the flash capacitor makes but this was detached earlier.
      • The pictures shown for the flash capacitor removal is from a complete tear down.
      Ask FixBot
    2. Nikon D610 Flash Capacitor Replacement: step 10, image 1 of 1
      • If your flash capacitor looks damaged you can create a discharge tool with this guide. Constructing a Capacitor Discharge Tool
      • Then use the plastic opening tool to pry from underneath the capacitor from top to bottom in order to remove it.
      • Please note that there is glue holding the capacitor to the frame so it will need some coaxing to get it off.
      Ask FixBot
Daniel Eagan
624 Reputation
5 Guides authored
USF Tampa, Team 4-4, Lacy Spring 2016 Member of USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,761
