Up to 20% off select tools
Nikon D5000 Sensor Filter Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
126
All Time:
6,555
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Need to clean out every last speck of dust? Scratched your sensor filter? Swapping out the filter for a custom modification? This guide can help.
    1. Nikon D5000 Sensor Filter Replacement, Back Panel: step 1, image 1 of 3 Nikon D5000 Sensor Filter Replacement, Back Panel: step 1, image 2 of 3 Nikon D5000 Sensor Filter Replacement, Back Panel: step 1, image 3 of 3
      • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
      • Unscrew the eight Phillips #00 screws on the back panel:
      • Two 2.5x6mm screws above the screen.
      • One 3x6mm screw on the upper part of each side (two total; right side shown).
      • One 3x7.5mm screw on the lower part of each side (two total).
      • Two 3x4.5mm screws on the bottom.
      Ask FixBot
    2. Nikon D5000 Sensor Filter Replacement: step 2, image 1 of 3 Nikon D5000 Sensor Filter Replacement: step 2, image 2 of 3 Nikon D5000 Sensor Filter Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
      • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
      • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
      • This procedure also applies to all of the other ribbon cables in the D5000.
      • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
      Ask FixBot
    1. Nikon D5000 Sensor Filter Replacement, Sensor Filter: step 3, image 1 of 3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: step 3, image 2 of 3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: step 3, image 3 of 3
      Buy
      • Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
      • Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
      • Disconnect a seventh ribbon cable in the lower-right corner.
      Ask FixBot
    2. Nikon D5000 Sensor Filter Replacement: step 4, image 1 of 1
      • Desolder the five wires attached to the back of the board.
      Ask FixBot
    3. Nikon D5000 Sensor Filter Replacement: step 5, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 5, image 2 of 2
      • Remove the five silver Phillips #00 4x4mm screws.
      • One is hiding under the wide ribbon cable in the lower-right corner.
      Ask FixBot
    4. Nikon D5000 Sensor Filter Replacement: step 6, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 6, image 2 of 2
      • Flip up the motherboard.
      • Remove the white cable connector by pulling it out of its socket with a spudger or fingernails.
      Ask FixBot
    5. Nikon D5000 Sensor Filter Replacement: step 7, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 7, image 2 of 2
      • Remove the L-shaped ribbon cable from both of its connectors.
      Ask FixBot
    6. Nikon D5000 Sensor Filter Replacement: step 8, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 8, image 2 of 2
      • Remove the three silver 5x5mm screws.
      • Between the metal backing plate and the standoffs for each screw is a copper washer. Don't lose them!
      • Flip the sensor board out.
      • Be extremely careful from this point on. Dust or scratches on any part of the sensor or its filters can affect picture quality.
      Ask FixBot
    7. Nikon D5000 Sensor Filter Replacement: step 9, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 9, image 2 of 2
      • Remove the four silver 3.5x3.5mm screws securing the dust cover.
      • Pull the cover straight up to remove it.
      Ask FixBot
    8. Nikon D5000 Sensor Filter Replacement: step 10, image 1 of 2 Nikon D5000 Sensor Filter Replacement: step 10, image 2 of 2
      • To remove the sensor filter, pull back the rubber gasket to expose the edge. Use a spudger or opening tool to carefully pry out the filter.
      Ask FixBot
3 other people completed this guide.
Author
with
Jacob Rardin
1,472 Reputation
6 Guides authored
Cal Poly, Team 13-28, Maness Spring 2014 Member of Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Members
72 Guides authored
2 Guide Comments
Excelente guía, solo que debo cambiar las cortinillas y creo que es por el frente de la cámara
alcova35 - Reply Share
Is the dust cover in step 9 just a clear glass or is it also a filter? In the picture, it has a pink tint.
pol techa - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 126
All Time: 6,555
