Nikon D5000 Battery Door Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
34
Past 30 Days:
146
All Time:
7,154
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Removing the battery door makes it easier to clean up after a battery leak or unscrew the bottom panel. It is also necessary for the installation of certain accessories.
    1. Nikon D5000 Battery Door Replacement, Battery Door: step 1, image 1 of 2 Nikon D5000 Battery Door Replacement, Battery Door: step 1, image 2 of 2
      • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
      Ask FixBot
    2. Nikon D5000 Battery Door Replacement: step 2, image 1 of 2 Nikon D5000 Battery Door Replacement: step 2, image 2 of 2
      • Grip and hold the front end of the battery door at a 45-degree angle from the case.
      • Pop the battery door out by pulling the front tab up.
      • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
      Ask FixBot
2 other people completed this guide.
Jacob Rardin
1,472 Reputation
6 Guides authored
Cal Poly, Team 13-28, Maness Spring 2014 Member of Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Members
72 Guides authored
1 Guide Comment
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Reply Share
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 146
All Time: 7,154
