Motorola Moto 360 Rear Cover Replacement
    1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
      • Set the watch face down on a flat surface.
      • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
      Ask FixBot
    2. Ask FixBot
    3. Motorola Moto 360 Rear Cover Replacement: step 3, image 1 of 2 Motorola Moto 360 Rear Cover Replacement: step 3, image 2 of 2
      • Gently slide the blue opening pick between the rear cover and the metal casing.
      • The rear cover is extremely fragile. Be very delicate when using the opening pick.
      • Work your way entirely around the rear cover.
      • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
      Ask FixBot
    4. Motorola Moto 360 Rear Cover Replacement: step 4, image 1 of 1
      • Once the adhesive has been successfully loosened, gently pull the rear cover off.
      Ask FixBot
9 other people completed this guide.
Cole Twitchell
1,697 Reputation
2 Guides authored
Cal Poly, Team 17-32, Amido Winter 2015 Member of Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Members
39 Guides authored
1 Guide Comment
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 42
All Time: 13,586
